Click for YF Listing Service Click for Burger Cick to Clean Black Water Click for Delta Click for JetForums
453 Electrical system
Discussion in 'Silverton Yacht' started by doorpro, Mar 5, 2009.
  1. doorpro
    doorpro Member
    Long Beach, Ca
    Hello again,
    I have recently been having troubles with my 50 amp ~ 250v system aboard my 453 and have replaced almost every fitting to do with the shore power as well as a very expensive cable.
    My situation my be a tad different than most with this or any other 250v yacht in as much as my dock doesnt have 250v yet so i use a smart Y to get 125v from my slip and 125v from my neighbors slip, I also have changed fittings, "y"s and cables on the next slip because they all showed signs of arcing.
    My question is now that i have spent almost a grand on this project ,would it be a good idea to use one of the silicon based connection grease products on all the connections to help keep out the salt, moisture and damp that gets past the waterproof boots etc?
    As usual, i thank everyone involved with this problem,
    regards,
    Doug.
  2. K1W1
    Your problem might be simply the fact that 125v + 125v doesn't equal 250v.
    A single phase AC Connection is comprised normally of 3 wires, Phase, Neutral and Earth. Even if you have 4 or 5 of these connections you will only have an increased current capacity ( at the origin anyways) not an increased voltage.
    I was once trying to buy a cooker in Ft Lauderdale for a 240V Boat, the tech who came to fit it assured me 240 was simply two lots of 120. He was sent away to do some homework and we fitted it ourselves.
    Are you sure it is 250V you need and that is not just the rating of the socket/plug you have?
    What voltage lights and electric motors do you have onboard?
    There are a few electrical guys who post here who might be able to explain this in terms you can understand.
  3. Pascal
    what problem are you having? no power at all on one or both of the legs? low voltage? popping breakers? hard to reply to your post without knowing the symptoms.
    The most important thing when it comes to shore power is to reduce loads and the turn off the main breakers before connecting and disconecting.
    typically, I shut down the Air Con breakers, water heaters and otehr signigicant loads, then switch the main breakers and rotaries off. On the dock side, i shut off the main breaker and then disconnect the cord.
    never disconnect under load as this will cause arcing. Never turn / swtich your rotaries with a load as it will cause arcing on the contacts and eventually cause issues.
    Obvioulsy, keeping the contacts clean, dry and using dielectric grease is always a good idea too.
    if your dock pedestal doens't have a 120/240-50 outlet then you have to use a smart Y and tap two 120/30 . the smart Y ensures that each 30amp outlet is on opposing phase and will only activate when both plugs are in and on opposing phases.
    obvoulsy, with a smart Y you are limited to 30amp on each leg instead of 50amp. you will still get 220v (30amp only) to power whatever 220v loads you have on the boat like Oven, dryer, air con or water maker.
    but again, what are the symptoms? throwing parts at a problem is never a good approach.
  4. doorpro
    doorpro Member
    Long Beach, Ca
    Thank you...
  5. doorpro
    doorpro Member
    Long Beach, Ca
    Hi Pascal,
    you are correct and i use the smart "y" and I always turn everything off before disconnecting power supply from the dock to the boat, however the original owner of the 453 didnt so I had problems there to fix. I still need to know if using the gel on all connections helps with corrosion and arcing troubles which you have answered and i thank you for "getting it"...
    regards,
    Doug.
  6. Pascal
    "A single phase AC Connection is comprised normally of 3 wires, Phase, Neutral and Earth. Even if you have 4 or 5 of these connections you will only have an increased current capacity ( at the origin anyways) not an increased voltage."
    actaully, here in the US if you connect to two outlets and the hots are on opposing phases you will get 240v between the two 120v hots.
    when using a single 120/240-50 cord, you have 4 wires: Ground, Neutral, and two hots. you will have 120v between each hots and Neutral, but you will have 220v acorss the hots.
    US 220v is different from europe. Over there you have 220v between Hot and Neutral.
  7. doorpro
    doorpro Member
    Long Beach, Ca
    Pascal,
    I am not having any issues once the power is aboard the boat, no breakers popping and nothing on my boat is powered by anything more than 125 volts.
    My main issue was that most of the fittings from the boat to the 250 volt cable, then to the smart "y" and then to the dock supply were all damaged due to arcing and when i bought the boat last year and the survey had suggested that I replace everything that I have now replaced and upon doing that it was suggested that i use the dielectric gel to help protect the connections but it was from a sales person at my local West Marine store and i have learned through the years that these people dont always know what their talking about so i turned to this forum which has been a great source of information to me in the past.
    thanks again,
    Doug.
    Yes, you can use dielectrical grease without any issues whatsoever.
    Most of the time arcing in connections is caused by trying to draw too much amperage for the supply size/connections. Many boats that utilize a 50 amp shorepower cord, could draw 70-80+ amps at a time, if you run everything and anything all at the same time. For example if the hot water heater is going, all a/c's have the condensors running and the stove and washer/dryer.......Many times when I use a heavy draw item like the stove/over or washer/dryer, I'll shut an a/c off or something else. Make sure you're never drawing more then 50 amps on your electrical panel.......I have seen many Y's that have had the ends fried off of them as well as many 50 amp cords melt the end where it plugs in on the dock from too much amp draw.........Another good measure is to feel the cord near where it plugs in at the dock and see if it's warm.......
  9. NYCAP123
    Doorpro, When I manage a transient marina awhile back we had more than a few boats come in with "smart" Y's that arced and popped breakers like crazy. DK what the deal was, but the regular Y's worked with no problem.
    2nd thought, do you have a voltage isolater on your boat?
  10. Pascal
    all the smart Y does is ensure both legs are on and connected to opposing phase before kicking in. Like eveything else, the arcing is caused by hot dis/connects under load.
    the reason why boats using smart Y pop the breakers is probably because they need to keep the loads under 30amps instead of 50.
    I use smart Ys on our 2 125/250-50 cords once in a while, at marinas that don't have twin 125/250-50, works fine, no issue beyond having to manage the loads.
  11. TedZ
    TedZ New Member
    Clayton, NY 1000 Islands
    I think Pascal has hit the nail on the head. Using the smart Y you are going to get 60 amps of 120 VAC at the most. That is effectively half of what you are going to get with the 50 amp cable which should provide 100 amps of 120 VAC. Load shedding is the answer. Run half as much load (on the watt meter) as you would ordinarily and you should not get damaged contacts.
    The "gel" you want to use is actually an anti oxidant of which there are many. Petronox is one i like but any anti ox will do. The term dielectric is very confusing as a dielectric is a non-conducting substance. If there is such a thing as a dielectric gel and there probably is, don't use it!
    Ted
  12. doorpro
    doorpro Member
    Long Beach, Ca
    Hi Tedz,
    thank you as well as then rest of the posters and i believe like you that Pascal did in fact hit the proverbial nail on the head and the load is obviously a problem that i shall address being that we have 5 AC units apart from washer/dryer, stove, SubZero fridge/freezers etc to contend with.
    I would also like to thank you for addressing my main concern here about the gel/anti ox products and i am going to purchase the one that you suggested and use it.
    My main problem here in Long beach is that the docks have been slated for rebuild in the near future and when that happens there are going to be less of the smaller slips and more of the 45' to 100' slips and a lot more with the 250v that i need so until then i will be careful to watch the load issue.
    best regards to all of the posters,
    Doug.
