Click for Perko Click for Ocean Alexander Click for Burger Click for Westport Click for YF Listing Service
43 Post questions
Discussion in 'Post Yacht' started by Greg Page, Feb 27, 2021.
  1. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Same set up with my old Ocean, it came that way already with 50amps split to A-120v/B-120v.
  2. Greg Page
    Greg Page Senior Member
    Annapolis MD
    If an owner would be willing to look in the helm access and see which terminal strip and terminal a couple wires attach to It would be a help in re-installing some missing on my boat. I want to reconnect the fuel gauge sender/signal wires (I'd like to have the analog tank levels along with the digital fuel burn readouts on the engine displays, all the rest of the gauges are now CANBUS). Also the prior owner installed new indicator lights but didn't hook them up so need to find where the wires to the bilge pump, halon, and generator status lights come from. Some may have been in one of the DD harnesses which are no longer there but I'm hoping at least some are part of the boat harness to the terminal blocks.
    Is there an access panel to the top of the holding tank? Would like to inspect the lines/fittings there and see if there is a tank full indicator somewhere. The tank drain under the galley floor I found.
    Does anyone know the manufacturer and model of the fuel transfer pump? Mine doesn't seem to have a data plate or is buried under the rust.
  3. cleanslate
    Cherry Hill, NJ
    Captain Greg.
    This just popped up in my mind you’re close to Worton Creek Marina on the Eastern shore just outside of Chestertown Maryland.
    Perhaps you pay a visit and talk to John LeClair or John Patnovic they may have wiring diagrams and various parts that might help you out.
    You may just have to drive over and try to finesse your way in there and get permission to look around for what you need in their shed. Or Post books/files , if they have them.
    Not sure how eager they would be to help you out over the phone you know how that goes.
  4. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    Holding tank access is under the guest stateroom bottom bunk
    My fuel transfer pump is a Reverso - Not sure if that is original equipment.. Suspect not.
  5. Greg Page
    Annapolis MD
    I pulled out the drawers and looked under the bunk but didn't see a obvious hatch. Do I need to crawl in or does the bunk bottom unscrew so you can get access under the bunk that way?
    Wonder if the reverso pump is the same as the one in the oil change system. Will take a look and see if it is rated for diesel.
  6. boatpoor
    boatpoor Senior Member
    If I remove the mattress from the lower bunk there is a removable piece of plywood over the holding tank.
  7. mwwhit1
    mwwhit1 Senior Member
    a
    I have a reverso for fuel transfer. The pump is not different for oil or fuel transfer. The impeller rubber is different. when you search for impellers, you will see one rated for diesel and one for oil.
  8. Greg Page
    Annapolis MD
  9. Greg Page
    Annapolis MD
    I found the holding tank access under the bunk. The tank is behind the drawers which is why I couldn't see any access through there. The panel in the bottom bunk removes to expose the whole tank. Beast holding tank access I've seen. It doesn't have a tank full sensor, so I may try to add that. I also found the heading sensor for the old/unused Robertson autopilot. Too bad they didn't put the new Garmin sensor in the same place.
  10. Stainless45
    Stainless45 Active Member
    Post 46 Long Island NY
    If it's a plastic tank like mine hold a flashlight to the top and view through the side- will tell you how full it is. My 46 has I think a 30-gal thank. Fills up pretty quick
  11. Greg Page
    Annapolis MD
    Can't easily see the side, it fills the opening pretty well.
