Click for Abeking Click for Ocean Alexander Click for Ocean Alexander Click for Cross Click for Northern Lights
32 volt system
Discussion in 'Electronics' started by hpm1, Feb 2, 2009.
  1. Capt J
    Yeah, but you'd have to have a totally seperate bank of batteries and battery charger for the 24 volt bank. The 12 volt is usually achieved by having a generator designed to use 12 volts for starting, and you can run your electronics off of that, and it too needs it's own battery charger. I agree with Kiwi, if you're going to repower ditch the 32 volt system, and switch your engine and house batteries over to 24 volts as well as all of your systems. You shouldnt have too many systems to convert. You can also use like a Newmar transformer for different voltage on small items but they don't work as well as batteries at that voltage.
  2. dennismc
    dennismc Senior Member
    Vancouver BC
    32 V systems
    Here in the PNW 32 v is still available for parts, starters, (you can use 24 v starters on 32v ok).
    alternators etc, etc...my 70 ft Stephens is mostly 32 v and so far all is well.
    If you do change down, re wire all the new voltage circuits.
  3. partgypsy
    partgypsy New Member
    Washington DC
    32 volts
    I know this is an old post and I generally agree with the idea of 24 volts. Before you start chucking your old wire (and there will be lots of it). Check the sizes already installed. My old Chris w/a 32 volt system (DD diesel's) used the same wiring as the 12 volt gas engime models being built in the same plant. Result was much heavier gauge wire than I need for 32v, but perfect for 12v.
    e.g. My 32 volt cabin lights run through #10 wire.
  4. Mako55
    Mako55 New Member
    Carribean
    32v HouseSystem
    I have 12v, 32v, 110v & 220v on my 72' S&S that all keep me very busy.... There are 16-2v batt's that make up the 32v system with a combination of 32-12v inverters to run everything as well as a Heart Interface control panel and Link-10 ga. to work the main Inverter Charger and monitor the 32v battery bank. Last week the 32v bank would charge but than drop to 10v or less as soon as charge was turned off, I isolated each battery and load tested, I found that 6 of the 16 tested bad.... I'm thinking that the other batt's where making up for the bad ones ?? I am trying to decide if I should switch to 4-8v batt's and do away with the 16-2v ones I have now. My main question is will these 8v batts have the same longevity and rechargeability as the others ?? I know the AH is much higher on the 2v batt's I have now but they are not easy to find. If anyone has input on this, I would like to hear from you...One day I will upgrade to 24v system but it is to costly at the moment with having to replace all the inverters, batts and motors that use the 32v. Let me also add that i'm in the Caribbean at the moment and will most likely have to order anything I need unless I can locate somewhere in Puerto Rico..... Thanks in advance for any help on this subject!!
  5. Pascal
    no point in downgrading to a 24v system... only downside of 32v is that you cant' got the corner small boat store and find things.... so it takes a little more plannign for spares but it's no big deal.
    2V batteries, are they Rolls? if so how old are they? they are supposed to last a very long time.
    if you need to replace these, you can indeed switch to 4 8v batteries. Depending on your engines, you may be able to use 8v golf cart batteries which are not only cheaper but much easier to carry and install. they work very well with my 8V71Ns for instance, and i know a number of people that use them.
    i have exide e4800 on my boat, they last about 4 to 5 years and cost about $500 per bank of 4
  6. Mako55
    Mako55 New Member
    Carribean
    The 2v batt's are atleast 10 to 15yrs old maybe more, I havn't been able to find out exactly... The single Yanmar is already seperated out and runs on 12v with a extra 32v alternator to charge sytem with engine while underway, so that's not an issue, I just didn't want to have a prob with the rechargeability since there is so much less lead in the 8v setup than the 2v and AH diff... the 2v batt's we have now don't have a name on them but are 10 x 6.5 x 15.5 and 120lbs each. If you think the 8v will do the same job than that will save me lots of wieght, headaches and time replacing the 2v.....
  7. Pascal
    well there is no free lunch... if you are reducing the overall size/mass, you will loose some capacity. can you do it? it depends on what you really need.
    you need to know how much AH you currently have.
  8. Mako55
    Mako55 New Member
    Carribean
    each 2v has 12oo AH @ 20hrs and the biggest 8v is 390 ah @ 20hs so I deff gonna lose alot.. I usually charge 32v when link10 ga. gets to -350ah so if that is the case I should brake even on the 8v setup ... does that sound right ????
  9. Pascal
    if you need to use 350AH, then you need AT LEAST a 700AH bank since deep cycle batteries shouldn't be discharged more than 50% and that his really the limit. ideally you want some extra capacity...
    8v Golf cart batts are about 200AH, give or take a few amps... so 4 sets of 4 will give you around 800AH at 32V from which you could pull 350AH. just.
    as i said early, there is no free lunch. you want the power, you need the lead. and dont forget that removing some battery weith may create a list depending on the boat and the bank location.
  10. Mako55
    Mako55 New Member
    Carribean
    the batts are located in center of galley, midship so that should be no prob with listing..... I will still have 16 batts on board but with less weight. I guess I'll have to make up my mind on getting the six new 2v batt's or all new 8v, guess it will depend on which ones i can find and how much $??? Thank you very much for your help and it has cleared up alot of my questions !!
  11. Pascal
    replacing just the bad ones isnt' a good solution. it's importnant that all batteries in bank are matched in size and condition, as much as possible.
    if you have a couple of bad ones in a new bank, 1 or 2 years old, it's ok... but not in an old bank like yours. the new ones will be taking a hit from the old one, in simple words
  12. partgypsy
    Washington DC
    32 v batteries
    You sound like you want to replace with what you're used to, because you're used to the capacity and it works, The Rolls battery site has all kinds of offerings including batteries that can more-or-less be disassembled into individual cells. They have a nice configurator program. http://www.rollsbattery.com/
    Also read up on what's going on in the solar area. These non-boaters have a very active and sophisticated handle on what works and what doesn't. Of course, weight is not their concern so much.
    I have a mix of systems and it works fine. I use T105's for conveniences like lights and electronics and my faithful 32 v system runs on the Exides mentioned above. Some might consider them a little underpowered, but you can always buy more and just about any auto supply dealer can get them for you quickly.
    I also have a Newmar 32 to 12 vdc converter... more for back-up than any necessity. I run it through a 200 amp a-b switch.
    Slightly off topic, but thanks Pascal for your idea of running the old school charger on a clock-timer. My 40 year old charger still works and shuts down when supposed to, but I know I won't boil them dry using the timer.
  13. Capt J
    I wouldn't even recommend changing one battery in a bank that is a year or two old. I did that once and had one changed under warranty in a bank, it had the same battery charger for both starting banks. The drainage from the new one to the old one caused the charger to go into charge mode, when the engine was started the next day the batteries blew apart into a bunch of pieces. Not good......From now on, I have always changed the entire bank.
  14. Mako55
    Mako55 New Member
    Carribean
    Thanks for input, I will deff replace all bettery's in the bank... with wich setup I'm not sure yet. Got alot of pro's & con's to look at
  15. Capt Ralph
    Hello All
    We have 2 x 32vdc banks. Made up of 4 x 8 volt batteries. I strapped a cable and switch off of the 3rd battery (24vdc) and made a terminating point behind the 32vdc switch & breaker panel shortly after buying our old girl 6 years ago. My thought was to slowly convert lights, blowers, pumps, electronics and more to 24vdc as they failed.
    That 24vdc stud has been collecting dust for almost 6 years now.
    I have had NO Problems getting 32vdc parts.
    I purchased a case of 32vdc lamps (household styled) and have used about half in 5 years (live aboard boat). They are still easily ordered and kept with spares (just like the 12vdc lamps you have on hand?).
    We currently have an inventory of 32vdc pumps, lights, motors and an extra, new 32vdc alternator (30si) for my old 12v71ti’s. Those 32vdc starters are big & bomb proof.
    We have also learned that the 32vdc stuff last longer. Drawing less current, less wattage, less heat may mean something. Remember, when voltage (E) goes up, W & I goes down.
    Taking our time in shopping, even e-bay has been helpful. I have purchased new 32vdc pumps at < half the cost.
    Naturally, we all want to keep spares handy. With some planning that should already be in place, a 32vdc system is NOT a problem.
    My 8volt batteries are just a few bucks cheaper than the big 8D/12volt. Half of what came with the boat, still test out like a new ones. Yes, thru the years, half of them have gone bad for some reason or another (some abuse). About the same fail rate as similarly priced 12volt batteries.
    So, yes, at first I was scared of the 32vdc system, then we learned, leave a good thing alone.
    Regarding the original post, we have a 1978, 58’ Bertram MY. Tinned wires on our Bert. Yours may be also and not have to be replaced after your dunking.
    If anybody comes thru the N E Florida area and need an emergency 32vdc part, look us up.
    , Ralph
  16. Marmot
    You might want to play with that relationship for a bit. :)
  17. Capt Ralph
    Remembering stuff from 30 years ago; W/ExI. If E volt goes up, then W watts and/or I current goes down. Or something like that.
    Where is a rocket scientist when you need one?
    , Ralph
  18. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    I remember from waaaayyyy back, that E=IR and Watts = IV, which would suggest if voltage goes up, then either the Watts go up or the current goes down.
  19. Henning
    Henning Senior Member
    Ft Lauderdale FL
    VxA=W Watts is what your gear uses to do work, so so as long as the job requirements are the same it will stay the same. So, when you reduce voltage, you need to increase amperage to do the same job. When you increase amperage you need to increase your wire gauges.
  20. dreamline
    dreamline Guest
    I have a 1980 Bert SF that came with 32 volt DC systems. I also installed a 12V stud in my DC panel and I have been slowly changing all my DC systems to 12V by changing the lead to the breaker from the 32V post to the 12V post and then changing the fixture (pumps etc.) It is just so much less brain damage to get the 12V stuff. I will leave the engine start system and some custom lighting 32 volt for the time being. One thing that really needs to become 12V are the engine gagues because there are no 32V gagues. I guess will just put the gagues on a separate switch from the start/run switches.
