Click for Northern Lights Click for YF Listing Service Click for Burger Click for Abeking Click for Westport
2018 Ft. Lauderdale International Boat Show (FLIBS) Coverage
Discussion in 'Boat Shows & Yacht Watching' started by German Yachting, Oct 28, 2018.
  1. Kevin
    Looking northeast from Elandess. Gene Machine is rafted next door. It was suppose to be on the face dock at the superyacht pavilion but draft exceeded depth.
  2. Kevin
    Pelican Bar at 66.
  3. Kevin
    Carl toured Abeking’s Aviva with the project manager.
    Paddle boards by Malibu - they are a work of art... much like the rest of the boat.
  4. Kevin
    Looking over Pier 66 marina from the aft deck of Aviva.
  5. Kevin
    Aviva has an airfoil mounted to the exhaust funnel. This was not a design exercise. It has a function. The lift generated by the top of the wing draws the exhaust up and over the aft deck.
  6. Kevin
    Aviva’s tender. Originally designed as a stepped hull but rollers on Abeking’s launch cradle would prevent deployment. This pic was taken as the tender went under the 17th St. causeway bridge.
  7. Kevin
    How does Aviva have such clean exterior lines? The air intakes are located inboard the superstructure, forward of the bridge.
  8. Kevin
    Aviva's decks double as a jogging track. There’s enough steps on this boat to eliminate the stairmaster in the gym.
  9. Kevin
    Some of the engine room pics we will use as reminders while writing. Everything you see was engineered by one of YF’s senior members.
  10. Kevin
    Is the crew being drug tested?
  11. Kevin
    Who can guess the boat this falcon landed on?
  12. Kevin
    At an after show party, Carl saw the perfect girl for Feadship’s Utopia. Or the Viking pictured earlier in this thread.
  13. Kevin
    Walking the docks after hours with Tom Serio, looking for some night shots... Came across a model from Oceanco with a previously unseen level of detail.
    Scale skills... impressive.
  14. Brian
    Brian Senior Member
    Halfmoon Bay, B.C. Canada
    Nice model...must have had a healthy budget for that!
  15. German Yachting
    German Yachting Senior Member
    West Coast
    I have a lot of photos of the show that I plan on sharing once it is wrapped up. It’s been quite busy here!
  16. YachtForums
    Had the opportunity to meet a remarkable person at FLIBS. He’s also a member of YF; GermanYachting, who joined us for a tour of Elandess. His knowledge on large yachts parallels IBM’s Watson. He’s a human stat machine!
    I think Tom Serio will upload a few shots later this week while I work on a Lurssen piece that showcases a number of stylistic designs for their new 50-meter platform. Yep, Lurssen’s going to build small boats. :D
  17. German Yachting
    West Coast
    A pleasure meeting you as well Carl! I’ll upload all the pics from the show soon!
  18. YachtForums
    I'm still in disbelief that center consoles are as big as yachts now. This is the new 52' Gulfstream Center Console. They are built in Tampa, across from the old Lazzara facility (now Bertram). Four Seven's are trying to pry themselves off the transom.
  19. YachtForums
    This is the new R-Class from Princess using an Active Foil System. Port and starboard foils adjust independently of each other. Their positions are calculated a hundred times per second by an onboard computer. Unlike typical foil technologies, AFS does not lift the hull out of the water. Instead, it adjusts the heel angle and attitude for the most effective contact area at various speeds. I haven't personally seen the system or tested it, but in a previous life this was an area of considerable research. I'm curious to see how the market receives it.
  20. Brian
    Brian Senior Member
    Great photos...any of Ocean Alexanders' booth?
