Click for Glendinning Click for YF Listing Service Click for JetForums Click for Northern Lights Click for Mulder
2001 Luhrs 32 Convertible - Runs hot.
Discussion in 'Luhrs Yacht' started by Thadd, Jun 23, 2021.
  1. Thadd
    Thadd New Member
    NJ
    Hi. Hoping others with my boat can give me guidance. I have changed almost everything in my cooling system on my 32 and my boat runs hot. I have the marine power 5.7s in the boat. I have addressed the following.
    1. New Risers and manifolds
    2. New intake hoses through the entire system.
    3. Impellars
    4. Exhaust hoses.
    5. Compression check. All good.
    6. Thermostats
    7. Water pumps
    8. Cleaned the heat exchanger. Barnacle busted and soaked closed side.
    Still runs hot when I go above 3500 RPMs. Gets to 200+ And if I run it long it will hit limp mode. Does anyone have this issue? Mechanic believes that the engines are undersized for the boat, but I have a hard time believing it. Hence. I am asking others who own one.
    Thanks.
  2. Thadd
    Thadd New Member
    NJ
    Sorry. Forgot to mention changed oil coolers too.
    Check for an air leak possible raw water pump sucking air........or collapsed hose while running at cruise.....or a blockage somewhere in the track. Undersized engines has nothing to do with it provided they hit WOT rpm. Do they? Also I think your boat has plates with holes on the bottom, check to make sure they're clear and not all barnacled up.
  4. Joe McKairnes
    Joe McKairnes Member
    lacey twp NJ
    Was engine work done? Timing off can cause it. What does the water flow at the exhaust look like? If it's strong, points to engine... perhaps even water circulation pump on front of engine...
  5. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    How long have you owned the boat? Is this a new issue or has it always run hot since you've had it?
  6. Rich Plukas
    Rich Plukas New Member
    Rochester, NY
    Thadd, somewhat similar problem drove me nuts last year but my problem was at low speeds. I was overheating on one engine and after chasing it for a few weeks we figured out the strainer seal was not working perfectly and it was causing the engine to suck just enough air to impede full water flow. Dogged the lid down clean and tight and problem solved. Worth a check because its simple and cheap. Good luck.
