Click for CL Yachts 99X Click for Burger Click for Burger Click for Delta Click for CL Yachts
1985 Hatteras 70' CPMY Fuel Consumption Rates?
Discussion in 'Hatteras Yacht' started by Live Wire, Mar 29, 2011.
  1. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
  2. kokeeffe
    kokeeffe New Member
    Newport, RI
    Much better going up than returning to FL
    If you are experienced then go offshore in displacement and use the extra 6 knots you gain following the gulf stream. Probably average around or slightly over 1g/mile but going south figure 3g/mile.
  3. Zacc
    Zacc New Member
    USA
    I was looking to buy one of these boats, can I safely cross the Atlantic in this boat? Would I need to add auxiliary fuel tanks? Is auxiliary fuel tanks possible? I live near Boston.
  4. Pascal
    Seriously ?
    Short answer is no. Even with auxiliary tanks, if you could even carry even fuel, as strong as these Hatteras are built they are not designed for ocean crossing.
  5. Capt Ralph
    Go out Buston about 100 miles and shut down your engines. In 8 to 12 months you should be able to drift close enough to get towed in.
    Your gen-set may only offer 80 hours of run time so be frugal for heat.
    hat4349 likes this.
