Click for Burger Click for Cross Click for Glendinning Click for Delta Click for Northern Lights
1984 46 viking 3 or 4 blade props
Discussion in 'Viking Yacht' started by Waytofast79, Dec 13, 2019.
  1. Capt Ralph
    In the back of my mind (way back there), I have accounted for the dynamics of the blades surface acting like a wing. However, this wing action works in a circle, lifting up, down, left & right.
    The only differences I could figure was the clean water and density on the blades in the lower swing. Shaft angle may help some also. Here is where a little extra performance may be found.
    My above comments have been towards; factory specs (diameter) and less sales propaganda.
    Vikings door are still open and support great. No comments on what they suggest yet.
    Here in the swamps, all kinds of snake oil has been tried on near anything that floats. We can't re-invent the wheel, but we can keep it clean with correct pressure was our lesson.
  2. chesapeake46
    chesapeake46 Senior Member
    I thought 4 blades give a smoother ride while 3 blades give a better bite for better maneuvering to your slip.
  3. Capt Ralph
    4 blades do offer less vibration.
    Not sure about better maneuvering but a good 3 blade is faster.
    Check #3 & 15 above.
  4. Boomer
    Boomer Senior Member
    Seminole
    You just talked me out of going to 3 blades..thanks for saving me some money!
  5. Capt Ralph
    Not sure who your thanking. If what you have 4 blade wheels; please offer some specs and performance numbers to help the thread.
  6. Boomer
    Seminole
    I have 4 bladed wheels now but pitch is way off....on list of things to do..original boat specs were 3 blades at 31 kts... I will be happy with mid 20s with the 4 blades
  7. Capt Ralph
    What are you spinning (rpm)?
  8. Boomer
    Seminole
    Right now I am 24x20p...cruise at 1950 is 14kts...should be up another 4 or 5 kts
  9. Capt Ralph
    High idle and wot RPMs?
    Mother in law on board?
  10. Capt Ralph
    I think the p is a typo.
    20" is not enough diameter.
  11. Boomer
    Seminole
    20P is correct...had to start somewhere as the blades were all out of whack from a grounding at speed when the mathers ZF throttles failed to pull back...I now figure a 24P would be closer to where I need to be on 4 blades...work in progress...I dont have my #s available...but I do remember port hi idle was 2450 and stbd was 3100...a little tall
  12. Boomer
    Seminole
    TI
  13. Capt Ralph
    24 is better, thank you for correcting me.
  14. Boomer
    Seminole
    NP....Merry Christmas Ralph!!
  15. Capt Ralph
    Safe, Merry Christmas & New Years to you, my friend.
  16. Capt Ralph
    Safe, Merry Christmas & New Years to All.
