Click for YF Listing Service Click for Abeking Click for Abeking Click for CL Yachts Click for Ocean Alexander
1970 53' Hatteras Yacht; full refit.
Discussion in 'Hatteras Yacht' started by Pascal, Nov 11, 2015.
  1. Pascal
    Took 5 months but we finally splashed and brought the boat home from the yard a couple of days ago.
    It took a long longer than expected for a bunch of reasons... we had to cut down the stringers and reglass them to accomodate the new engine and gears. Also had an alignement issue with the aft struts. Had to launch the boat for a couple of days so the hull regain its shape, get some reference marks to check the blocking and move th struts a inch or so. Perfectly aligned now. I suspect the old two piece shafts had more flex than the new single piece 20' AQ22
    Also sealed 8 or 9 old thruhulls, installed new TRAC stabs (and reinforced the hull), Had to run new 8" exhaust to the stern (used to be 6" for the old DD) which required a lot of csbinetry cutting in the master... rebuild the hynautic helms and ram, new fuel hoses and manifold, installed new trim tabs and a lot more
    Still have some issue to work out like finish bleeding the steering, solve a glitch in the cummins analog gauge panels, etc.. and then a year of interior work...
    Here are three quick clips of the launch and run home. Swipe to get to all 3. Ran mostly at hull speed on the way home from the miami river to the grove except for brief run at cruise RPM. Hit 17kts, silky smooth and no vibration. Will do a proper sea trial with mech in a couple of weeks when we get back from an uocoming trip to the exumas and will have unloaded a low of weight from the boat (tools, parts, etc...). Hopefully will turn rated rpm and target top speed of 20kts
    Engines are loud in the video as the ER doors were open... and yes i m fighting air in the steering :)
    https://instagram.com/p/Bi0dL44D1Bc/
  2. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    Congratulations, the old girl has new legs, 17 knots with fin stabilizers, very nice!
  3. Pascal
    Should have mentioned the 17kts was at 2200 rpm out of the rated 2600.
  4. PacBlue
    Dana Point, Ca
    Looks like you have at least 2" of pitch to take out, this may be tough on old re-conditioned propellers.
    It would be good to work with a local prop shop who may have some alternate props that you can test before settling on the final solution.
  5. Pascal
    I won't know until we do a full sea trial. Let me clarify that the 2200rpm and 17 kts was NOT full throttle. We may turn 2600 on the pins. I don't know yet
    That's why I had my props re con d. Then when we do a proper sea trial I ll see if I need a new set.
  6. unsinker
    unsinker Member
    Puerto Vallarta, Mexico
    Hoping Aaron Schlossberg does not read this post, watches either your video or sees your boat in US waters, great boat's name!
  7. Pascal
    The 12' strip planked cat boat on the top deck is named Sabrosa and we have a 26 strip planked gaffer that i built named Sabrosura :).
  8. unsinker
    unsinker Member
    Even better, great project, thank you for sharing and congratulations for knowing the challenges, going forward with it!
  9. John Hoch
    John Hoch New Member
    Central Florida
    I know its been a yr since the last post but could you update us? We are going to look at a 50 just like this on the 13th. The wife lives the galley up idea..
  10. Pascal
    Slowly making progress but far from being finished. Been busy with the 84 footer we run, lots of time in the Exumas plus other projects. I have torn down the forward stateroom and head, build a centerline double bed and I m about to build a new forward head where the dinette used to be
  11. John Hoch
    Central Florida
    If you get a chance I'd love to see pictures of that... we are very inspired by your work sir. Thanks
