Click for Glendinning Click for Cross Click for Burger Click for Delta Click for Nordhavn
Review: Trinity 161' "Destination Fox Harb'r Too"
Discussion in 'Trinity Yacht' started by YachtForums, Nov 19, 2008.
  1. A fourth guest stateroom offers twin berths in well-groomed carved wood frames, with opposing walls in light gray, also in the quadrangle pattern. With windows, ensuite head/shower, there is also ample closet space and a small writing table. Forward, Crew Quarters include three double-bunk staterooms, plus a separate recreation, dining, and entertainment area.
  2. On the lower deck, aft, twin engineer/communications offices provide living quarters as well as total electronic monitoring systems for the yacht. Just forward, the beam-wide engine room houses her twin 2,250 hp 3512B Caterpillar engines, which drive the aluminum hull at maximum 20 knots; 18 knots cruise. The wide beam allows full walk-around and overhead space for servicing the two work-horses. In addition she boasts Quantum stabilizers with digital controls, a Quantum 150 hp bowthruster, plus twin 99kW generators for in-house power, as well as a 9,842 liter/day watermaker, and 50-ton Dometic air conditioning system.
  3. In Trinity’s storied years of dedicated yacht-building, the company has thrived on its creativity and fastidious attention to detail in satisfying the cruising needs of its customers in the world’s yacht market. Destination Fox Harb’r continues its engineering and operational excellence with another beautiful and client-pleasing megayacht.
    Next to the 19th hole, Fox Harb’r is the last, best place to be… ​
    <end>
    Review by Capt. Chuck Gnaegy​
    Specifications:
    LOA: 164 ft.
    Beam: 28 ft.
    Draft: 7’9”
    Displ.: 317.3 long tons
    Construction: Aluminum
    Fuel: 16,000 gal.
    Water: 2,600 gal.
    Power: 2x Caterpillar 3512B @ 2,250 hp each
    Speed: Max 20 knots
    Cruise: 18 knots
    Range:
    Naval Architects: Trinity Yachts, LLC
    Interior Design: Patrick Knowles
    Classification: ABS Maltese Cross A-1 Yachting Service, AMS, MCA Compliant
    For more information contact:
    Trinity Yachts
    13085 Seaway Road
    Gulfport, MS 39503
    (228) 276-1000
    www.trinityyachts.com
  4. Deck Plans: Upper GA's...
  5. Deck Plans: Lower GA's...
