Click for YF Listing Service Click for Perko Click for Abeking Click for Mag Bay Click for Westport
Tender Storage on Foredeck
Discussion in 'Viking Yacht' started by 92Searay-37', Sep 3, 2017.
  1. 92Searay-37'
    92Searay-37' New Member
    Baltimore
    Looking to store Tender on my foredeck of 1989 45' Viking Convertible.
    What would be he weight capacity?Tender will weight about 400lbs.
    I called Viking but no response yet.
    Thxs!
    400lbs shouldn't be an issue structurally. It will effect ride a bit. How much, who knows.
  3. Trinimax
    Trinimax Senior Member
    Bwf
    400 pounds should be fine. But also don't forget to factor in the weight of the winch. Might be a good idea to fill a barrel with freshwater tied to the foredeck and take the boat for a run to see how the ride is affected before you start the project
  4. 92Searay-37'
    Baltimore
    Thanks for the replies.
    Hopefully Viking calls me back this week.
  5. Capt Ralph
    400lbs sounds light for a small tender, with outboard, gear and the weight of chocks and the davit.
  6. 92Searay-37'
    Baltimore
  7. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    Better make sure that the tender can't fill with water,...LOTs of added weight.
    At one time I was looking to design a 'transomless' RIB for just this reason.
  8. MBevins
    MBevins Senior Member
    Windsor On. Canada
    You won't have any problems. I have a 44Viking with a davit and 11' Caribe Console. The boat handles it fine. In fact I carried a 14 Novourania Console up there for a while. It was about 900#.
    Fuel consumption went up about 10% when hauling it around so only did short runs with it.
    When selecting a davit , if you don't have one, make sure you get an aluminum one (weight).
    My avatar image shows the dinghy on the bow.
