Click for Nordhavn Click for JetForums Click for YF Listing Service Click for Abeking Click for Furuno
Swift Trawler 34 Water Problems
Discussion in 'General Trawler Discussion' started by Stuart M, Dec 6, 2016.
  1. Stuart M
    Stuart M New Member
    Lymington
    We have just taken delivery of our new (well secondhand) ST34 and brought her back from Falmouth to Lymington.
    During the trip I lost autopilot and then on arrival no stern thruster.
    A closer look reveals water in the area where the thruster exits the boat which sits lower than the rest of the lazerette.
    Sadly the complicated box of electrics had not be fixed and was floating in sea water.
    No water anywhere else and no water ingress since we arrived.
    It was a tad rough on the way back but I'm guessing we shouldn't expect sea water inside the boat.
    Any thoughts would be appreciated
    Stuart
  2. Prospective
    Prospective Senior Member
    New England
    How deep are we talking. Sounds like a lot. You definitely shouldn't get enough water to float battery boxes. You need to start doing a very complete inspection to determine where this water is coming in. If you determine the leak is not happening at rest, my next guess would be shaft seals that are only leaking under way.
  3. Stuart M
    Stuart M New Member
    Lymington
    The area that filled with water is separated from everything else in a recess about 12 inches deep and say 15 inches square.
    I can only think that in a heavy sea water can back flow through stern thruster mechanism.
    Had a good bug like this years ago.
    Exterior trim from the transom swim platform continued forward up the hull sides for 4-5 feet.
    It also served as an additional hull side rub rail.
    At rest all is good.
    In a sea, water would enter the bilges where the trim was bolted to the hull.
    When we looked under this trim, the factory caulk was missing. It was also a poor factory fit and assembly.
    What's low on your hull sides?
    Vents, trim rails or a thru hull with a bad hose behind it?
    Swim platform or ladder thru bolt?
  5. Stuart M
    Stuart M New Member
    Lymington
    Thanks. I will have a good look. I'm still hoping the black box of electronics might yet come back to life - an expensive first trip!
    With power off, wash out the box with WD-40 and let dry for a day. If you have old relays in there try to remove the covers and wash again with WD-40.
    Good luck
  7. Stuart M
    Stuart M New Member
    Lymington
    Thanks I'll give it a try
    Is it safe to flood electrical circuits with WD40 - might be a daft question
  8. Jonza
    Jonza New Member
    Palma de Mallorca
    +1 on WD 40. Also, a remedy that sometimes work, sometimes not, is, after perhaps flushing device w. fresh water and WD 40 - put it in a couple of plastic bags or a can/jar/bucket filled with dry unboiled white rice for a day or so (!). Make sure there is no contact with outer air using tape or rubberbands - the rice might, just might, "suck" the remaining humidity out of Your Black box. Won´t hurt to try + it´s super cheap - sure helped me save a few cell phones (don´t ask).
  9. Metatron
    Metatron New Member
    Calgary
    You probably want to use fresh water before WD40. The fresh water will dissolve any salt. Then maybe distilled water. Basically, you need to get the salt off the electronics otherwise it will corrode away.
    To get the water out, you can use isopropyl alcohol. It will remove the water.
    Once you have everything as clean as possible, let it dry for 24 hrs or so. You can also stick it in an oven on LOW ( < 150 deg F ).
  10. Stuart M
    Stuart M New Member
    Lymington
    Thanks to everyone I'll go down tomorrow and see what I can salvage.
    Stuart
