Click for Mulder Click for Westport Click for Northern Lights Click for YF Listing Service Click for Nordhavn
School me on Watermakers
Discussion in 'Watermakers' started by PSW, Jan 31, 2017.
  1. Pascal
    Good luck with that ... there is no way you will make potable water at 100psi
    If you believe that... you believe you kept your plan and your doctor :)
  2. Knight
    Knight Member
    Fishersville
    Unless filtering saltwater is different and needs more pressure. It's not much different than using a RO in your home. I would curious if the same system would work on a boat. Just throwing out some ideas.
    O I never believed anything that man said lol. Still don't!!!
  3. bayoubud
    bayoubud Senior Member
    Florida
    Right need 800 psi or more for saltwater. I think Knight is talking about RO setup for freshwater for household use..
    RO pressures:
    Freshwater 50-225 psi
    Ground/Brackish 100-600 psi
    Saltwater 800-1200 psi
  4. Knight
    Knight Member
    Fishersville
    Yeah you probably need high pressure for high gph. O well I thought I was on to something.
  5. captholli
    captholli Senior Member
    In The Bilge
    High pressure is required to separate the fresh water molecule from the salt water through a permeable membrane.
  6. bayoubud
    Florida
    You are, I recently learned the difference in RO pressures when I was trying to figure out how to make spotless water to wash a boat without spending a bunch of money on a marine watermaker.
  7. captholli
    In The Bilge
    De-ionization or a D.I. system can be home made from a 3"x 24 '" schedule 80 PVC pipe with end caps , 3/4" male and female hose fittings in each end & a suitable plastic media and rock salt. You can make a reliable & rechargeable system for spot free water for $75.00 or less if you do a bit of home work design & parts wise.
  8. bayoubud
    Florida
    Sounds simple, I will look into it. Thanks
