Click for Ocean Alexander Click for Mag Bay Click for Mulder Click for Abeking Click for Burger
New Oil Change System
Discussion in 'Yacht News; Builds & Launches' started by YachtForums, Apr 2, 2005.
  1. NEW AC OIL CHANGE SYSTEM MEETS DEMANDS OF LARGER VESSELS...
    An oil change system can make maintenance easier for any boat, large or small. With its GP-806 Oil Change System, Reverso Pumps has created a durable, AC-powered system well suited for larger recreational craft, commercial vessels and workboats.
    Each oil changer can service multiple engines, transmissions and generators. With increased lift capabilities, the unit can move oil and other viscous fluids 30' vertically. Its heavy-duty gear pump can handle
    3-1/2 gallons per minute. Five-valve and six-valve systems are available.
    Reverso's rugged, all-metal system features a corrosion-resistant, powder-coated stainless steel base and cover with an aluminum manifold. Its pump is constructed with a brass head, bronze gears and stainless steel shaft.
    Available in either 110 or 220 volts, the totally enclosed, fan-cooled AC motor is UL-listed and CE-certified. At 20 PSI, it draws 3.4 amps at 110V and 1.7 amps at 220V. Weighing 30 pounds, the unit is 17" wide,
    13-1/2" high and 6-1/4" deep.
    Reverso Pumps also manufactures a complete line of DC-powered manifold oil change units as well as fuel polishing systems.
    Suggested prices for the GP-806 Oil Change System begin at $2,000.
    Contact Reverso Pumps Inc.
    201 SW 20th Street
    Fort Lauderdale, FL 33315
    Phone: 954-522-0882
    www.reversopumps.com.
