On road on the water or what? There is no such thing as cheap transportation. If you pay peanuts, you get monkeys and in the end with a lot of damage that costs thousands more than paying a reputable source.
Define 300miles Over land On water Yacht? Do you really expect intelligent replies to such a vague question??
A 36 footer should be easy to put on a trailer... Frankly the best way to find a hauler will be to check with local marinas and yards on the lake, they ll know who to use
If it has an arch, probably going to have to remove it. I think the bridge will probably clear otherwise, but not sure. If not, then will need to remove it.
OK,sorry From DFW area to Lake Travis Yes it has an arch. I ve pulled a 30' Sport Cruiser all over ,but haven't found a trailer big enough yet. Thanks
Carver told me that the 3607 height is 14'11" Probably will have to lay down helm. Can anyone tell me what is involved
The specific standards for vertical clearance adopted for the Interstate System maintain its integrity for national defense purposes. On Interstates, the clear height of structures shall not be less than 16 feet (4.9 meters) over the entire roadway width, including the useable width of shoulder. In urban areas, the 16-foot (4.9-meter) clearance shall apply to at least a single routing. On other urban Interstate routes, the clear height shall not be less than 14 feet (4.3 meters). A design exception is required if this standard is not met. Exceptions on the Interstate must also be coordinated with the Military Surface Deployment and Distribution Command Transportation Engineering Agency of the Department of Defense. Having said that, arterial, access and local roads may have lower structural clearances not to mention power lines and pole trusses. Reputable haulers will do the homework for you. As for taking the boat apart, there's a lot to it, even just lowering the arch. I don't know your area at all but I'm going to assume there is no way at all from point A to point B on her own bottom. If there is, I would take it, even if it's several days journey.
