Click for Burger Click for Westport Click for Glendinning Click for Furuno Click for Abeking
Carver 4207
Discussion in 'Carver Yacht' started by Captrko, Jul 24, 2012.
  1. JETJOCK
    JETJOCK New Member
    Cape Canaveral
    Well ...I would not sell her for 150% since I have spend a significant amount of money and time righting all the wrongs. Don't take it so personal, but this was your first big boat and it was too much to chew on. You were lucky you found a guy who had the cash to pull off a sale quick, there is still a lot of boats not sold around here.
    Today she got her tanks filled with 93 Octane. Probably the first time in a long time that boat has had full tanks. I am still pissed at the "uprigging" job the marina did, they actually cut wires installing the radar arch. Just installed Apple TV, can run all the electrical outlets via my iPhone or Ipad, got the windlass working (the switch was installed upside down by the way) got the crane working (big piece of crap that I will remove anyway since my dink is light and I can pull it aboard single handed.) The couch had to be thrown out as it was falling apart, I junked pretty much everything in the boat and started over. You will be happy to know that the steering system is fine once you added some fluid to the system (5 min fix) and again I am surprised the uprigging folks didn't catch that one.
    Bottom line is the boat is mine and I am making her the way I want her, the next guy will undo my "screw ups" and change her to his liking.
    If you want to offer me 200% well there is a 60' Chris Craft Roamer that I would like to move up too.
  2. MysticDolphin
    MysticDolphin Member
    Lake Texoma
    mine... Texoma
  3. captnrontx
    captnrontx New Member
    Lake Texoma
    Where are you located on Texoma?
  4. MysticDolphin
    Lake Texoma
    IM located over at Flowing Wells... very parklike marina and very affordable...
  5. Phillip J
    Phillip J Member
    Mariner's Marina, Seneca, IL
    Mystic,
    Where did you have those stairs fabricated? I want them.:cool:
  6. MysticDolphin
    Lake Texoma
    Nautical Stuff • 3335 Juanita Drive • Suite 101 • Denison, Texas 75020
    903.463.5002 • E-mail Nautical Stuff
    these are the folks that made them for me per my instructions... they have numerous other ideas for this application.
  7. Phillip J
    Phillip J Member
    Thanks, I'll inquire with them......:D
  8. Fet-ish
    Fet-ish New Member
    Lake of the Ozark, MO
    4207 stairs
    The person I bought my vessal from had the spiral staircase from a Carver 440 installed on my 1988 4207 and it's been one of the best features on the boat.
  9. Captrko
    Captrko New Member
    Kemah Texas
    I want one!
    Where can you get a 440 stairs? Anyone know who makes them?
  10. Fet-ish
    Fet-ish New Member
    Fet-ish TV
    Here was my idea for the flat screen in the salon. I did this in 2007 and I'm about to update the TV. I just realized this one looks like a dinosaur...
  11. Fet-ish
    Fet-ish New Member
    4207 stairs
    The boatyard where I used to keep the boat at did the custom work on the stairs. It included the notch that had to be cut-out of the stern to be use as the first step. I think the guy I bought it from said, "it was $3700 (new) for the steps from Carver and it was about $4000 fiberglass work and installation." I know...Ouch! Probably would have included a divorce if I had tried to do it...
    Here is the TV.
  12. Fet-ish
    Fet-ish New Member
    Fet-ish water tank
    Now I have a question. I have a leak in the fresh water tank under the galley floor. As most of you probably know, Carver generally used a soft rubber 150 gal tank in a large pie-shaped tub. Has anyone had success repairing or replacing it???
  13. autowerks
    autowerks Member
    Chicago Illinois
    I have never noticed the holding tank under the galley floor. Is it accessed through the engine room? I have had a leak for awhile in what I thought was in a pressurized line so I turn the pump off when not in use. Last night I ran out of water although the pump has not been on in a week.
  14. MysticDolphin
    Lake Texoma
    for the aft head my holding tank is in the engine room on the port side and for the head nearest the galley it is in the wall beside the stairs .. panel comes off .. I have the model with two large bathrooms, does not have an eating area at the galley...
  15. autowerks
    autowerks Member
    Chicago Illinois
    I was referring to the fresh water tank
  16. MysticDolphin
    Lake Texoma
    sorry my bad.. my fresh water tank is aluminum and under the aft bed.. masters cabin...
  17. captnrontx
    Lake Texoma
    Yep, I know you from 6%ers
  18. captnrontx
    Lake Texoma
    I have same exact stairs on my 370
  19. MysticDolphin
    Lake Texoma
    yes I am and I am at Texoma as well..
  20. Fet-ish
    Fet-ish New Member
    Fresh Water Tank
    MysticDolphin, How big is the aluminum water tank under the aft master bed? I would like to do something different for fresh water as the forward bladder tank under the galley/stateroom floor is one of the worst engineering designs I've ever seen.
    Carver designed it with no access to the tub or tank (150gal). You can barely see it when you stick your head in the forward bildge, let alone get your hands on it. I love my Carver, but I can't believe they thought a large flat rubber tank with a compression panel on top would last forever (or maybe just till engineer retired...).
