Click for Delta Click for YF Listing Service Click for YF Listing Service Click for Mulder Click for Perko
Carver 355 holding tanks
Discussion in 'Carver Yacht' started by n36511, Feb 11, 2013.
  1. n36511
    n36511 New Member
    Lake Lanier, GA
    Do any of you 355 owners know the holding tank sizes and is there an easy way to view them. I do not have tank monitors and they filled up on me this weekend.
    Thanks again for all of the help!!
  3. Phillip J
    Phillip J Member
    Mariner's Marina, Seneca, IL
    Waste - Unless modified, You have two 18 gallon tanks. one fore and one aft.
    Aft tank is located under the carpet just to starboard and a little forward of the birth in the aft stateroom. peel the carpet back from a point just below the nightstand next to the bunk and it will reveal two access panels, aft is for your aft bilge pump and the one forward is where you rear tank sits. I agree with CAP you may need to change your filter if overflow occurred. Your forward tank is located under your galley floor just to the rear of the floor access panel. There you will find your tank and macerator.
    Fresh water - located under the Aft Cabin bed. 81 gallons. These are all easily accessible and easy to install a tank monitor. If you stay on your boat a lot like I do, Invest in a good monitor.
    Good luck!:)
  4. Phillip J
    Phillip J Member
  5. n36511
    n36511 New Member
    Lake Lanier, GA
    Thanks all!! Man those are small tanks! Weekend trips on the lake with my two daughters and wife will fill them up quickly :) . I am coming from a house boat with a single 80 gallon tank. Of course I never liked riding around with that much stuff on board.
  6. 355aftcbn
    355aftcbn New Member
    Erie, Pa
    Where are the filters? I have a 98 355 Aft Cabin and have not run across filters on the holding tanks anywhere!
  7. NYCAP123
    If you have a Vacu-flush head you should have a filter in the vent line. It's cylindical, about 2" in dia and a foot or so long, made by SeaLand. They're easy enough to change, although the job can get nasty. Here's a link so you can see what you're looking for: Vent Filters - Dometic Sealand
  8. 355aftcbn
    Erie, Pa
    Yes, I have the Vacu-flush head. I have never seen anything like that but as soon as the weather warms up where I can get to the boat I will check it out. Did Carver include them from the factory or are they an add-on later? I am shocked that I have not seen them as I have been all over the boat. Thanks for the info!
  9. NYCAP123
    Standard with vacuflush heads. In fact I'm not even sure they can operate without them. BTW, if you go past full those filters are shot. They're generally put in a fairly accessable location, but I have seen them buried pretty good as the other poster seems to be finding out. Always remember that this is your boat. Don't be afraid to explore those little hatches.
  10. 355aftcbn
    Erie, Pa
    Ok. Thanks! I have been in every hatch numerous times that is why I am shocked that I have not seen them. As soon as the weather breaks I will check it out.......
  11. True North
    True North New Member
    St Paul, MN
    My 1997 355 did not have filters, I installed them myself this spring. Very simple to install and work great.
    Good luck!
  12. Monepit
    Monepit Member
    Evansville, in
    Mine had 4 20 gallon tanks. Two in front and 2 in the rear under the floor next to the bed.
  13. RB480
    RB480 Senior Member
    New Buffalo, MI
    Generally most carvers did not have the filters. 20 years on mine without filters. No smell, nothing.
  14. Ken Blass
    Ken Blass New Member
    Old Chatham ny
    I got to my boat last night to find a smell of sewage. It turns out that the forward black water holding tank is leaking into the bills right at the inlet.
    As anyone replaced these tanks before or had a leak and sealed them up? Anyone know where I can get a replacment tank? And if I am going to replace a tank anyway is there Room to increase the tank size I believe they're 18-20 gallons now
  15. MarinaMarie
    MarinaMarie New Member
    Mackinaw City
    Can an 18 gallon holding tank be changed to something bigger on a 355 Carver aft?
