Click for Ocean Alexander Click for YF Listing Service Click for Mulder Click for Perko Click for Nordhavn
Californian Convertible Sportfisher
Discussion in 'General Sportfish Discussion' started by Robertoman, Jul 14, 2015.
  1. Robertoman
    Robertoman Member
    San Diego
    Does anyone have any comments on "Carver"/Californian sportfisher's built in Tustin, CA 1988 vintage. I am looking at one with low hour 6V92s @ 550. Looks to me to be a Viking on Steroids.
    I am not seeing very much here about older Californians.
    I thank you all in advance
  2. Robertoman
    Robertoman Member
    San Diego
    Here is what I know. 42' 47.6 oal. 38000# 4'6" draught 15* dead rise 1800 rpm 16k hull 2" solid core, decks 3" end grain balsa core, have core samples. Factory 6V92 TAB engines built for Californian. 1 of 11. Anybody know any interesting info?
  3. Robertoman
    Robertoman Member
    San Diego
    Do the Detroits attract or scare fish?
  4. RER
    RER Senior Member
    Newport Beach CA
    The Californians, Marshall/Carver/Wellcraft of the 1980's to early 90's are considered well built and enjoy a popular place in the brokerage market. Most are aft cabin and were offered with or without cockpit. They did build some convertibles such as the 42 however those really did not enjoy the same popularity.
    Most old timers will tell you that Detroits have always been thought to attract fish.
  5. Kafue
    Kafue Senior Member
    Gold Coast Australia
    Seriously?!
    That's what is heard when you tell some people that Detroits attract fish!
    They do IMHO! and in the opinions of many fishermen I have spoken to.
    Unless there are bananas on board, then you can forget catching anything.
  6. Robertoman
    Robertoman Member
    San Diego
    No Bananas. My wife didn't believe about bananas, she does now though.
    This question is about checking on loaded RPM's.
    During the sea trial the mechanical surveyor tested both mains for rpm under load.
    Is the usual procedure to let one engine idle, and run the other wide open and check RPM, reverse and repeat.
    These engines are rated @ 550 @ 2300.
    The survey reads.
    "During sea trial the wide open throttle was 2256 rpm and 2196rpm port and starboard respectively as read from the analog tachometers".
    I am just curious, as it seems to me if both engines are at full throttle the load factor would be less and rpms higher from the help from the other engine.
    The engines weren't checked for high idle. Nobody wanted to see broken parts flying around I guess. :confused:
    Hope i posted this in the correct forum.
    Thanks,
    The engines should be checked for full throttle RPM with BOTH of them at full throttle in gear. They are propped to achieve 2300 RPM's at WOT with both engines at WOT. It is common for one to be a little more or less RPM's than the other. I would think those readings are with both engines at full throttle as usually 1 at idle and 1 at WOT, it won't achieve anything near rated WOT rpm's. I would think in todays day and age the surveyor would use a photo tach for an accurate reading and not rely on the boat's tachometers.
    Detroits do attract fish. Look at Boneshaker a Whitacker SF out of Jupiter/Stuart,FL.....used to win all of the sailfish tournaments in the area, ALL of them, it was the slowest boat in every tournament, latest to get to the fishing grounds and first to leave and cruised at 12 knots......they repowered it several years back and it doesn't do anything near what it used to in tournaments
  8. Kafue
    Kafue Senior Member
    When my Hatteras arrived in Newcastle, Australia, I sailed her North to the Gold Coast with my son as crew. About a 400 Naut. Mile trip. We had no game poles at the time. 2 fishing rods, a few lures (hardly a spread) and weren't headed to any particular fishing spots, just pointed the bow homeward.
    We caught pelagics right up until we decided we had enough of the fishing, time to just relax and cruise.
    The boat and Detroits definitely raise fish!
  9. Robertoman
    Robertoman Member
    San Diego
  10. Robertoman
    Robertoman Member
    San Diego
    That is a beautiful boat, I saw the transport and unloading, a trip of a lifetime. All the best to you guys!
  11. Robertoman
    Robertoman Member
    San Diego
  12. Kafue
    Kafue Senior Member
    Thank you, were you in the time?
  13. Robertoman
    Robertoman Member
    San Diego
    Thanks Capt J,
    I appreciate your time and knowledge!
  14. Robertoman
    Robertoman Member
    San Diego
    I wish, had to work, but, somebody has to do it.
    "San Diego, how bad could it be?"
