Click for Westport Click for YF Listing Service Click for JetForums Click for Cross Click for Furuno
46 Post- want to add Glendenning Cable master
Discussion in 'Post Yacht' started by My Affair, Jun 20, 2016.
  1. My Affair
    My Affair Member
    Mystic, CT
    I have a 1988 46 Post and I want to add a Glendenning cable master. Where if you have it, does the cable coil go and if you have pictures of your installation, that would be helpful too.
    My thought is to put the coil of cord in the storage area forward of the Startboard engine.
    Thank you.
  2. bigg1069
    bigg1069 New Member
    clinton ct
    You are correct that is where they mount it. I will try to send pics when I get down the marina tonight
  3. shawn
    shawn New Member
    old saybrook ct
    I put the bucket in back of my Starboard engine and the unit is in front of the fuel fill hoses.
  4. My Affair
    My Affair Member
    Mystic, CT
    Thanks!
  5. chesapeake46
    chesapeake46 Senior Member
    What engines do you have ?
  6. RT46
    RT46 Senior Member
    mine is above the batteries centered on the rear engine room bulkhead
  7. P46-Curaçao
    P46-Curaçao Senior Member
    Mine too (1981/46)
  8. My Affair
    My Affair Member
    Mystic, CT
    6-71 TIB's
  9. My Affair
    My Affair Member
    Mystic, CT
    How does the cable get over to the centerline? I was only on one 46 that had a cable master, I believe the basket was outboard of the hot water heater located under the battery charger area.
    Thanks!
  10. RT46
    RT46 Senior Member
    woops, sorry, after reading this a second time I realize you were referring to the cablemaster, not the engine sync.
    I don't have one.
    the cablemasters I have seen on 46Posts have been forward of the starboard engine.
  11. chesapeake46
    I was asking Shawn what engines he had because of where he said he installed the bucket and I don't see where it could fit. I thought maybe there was more room if you have 6-92's rather than 6-71's.
  12. RT46
    RT46 Senior Member
    yea, sorry, I read the post wrong, sorry
  13. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    I have 692's on a 91 46. The bucket is on the starboard side forward of the engine near the bulkhead. The cable comes straight in from the starboard cockpit hole. In out and off toggle gets wired there too.
    For all with the old yellow cable, marinco makes a replacement for that cable in White. Two part numbers are available; one is a 55' and one is a 75'. If you want the best price you can get it from CWR electronics in NJ online. Much less than Port or Lewis Marine's wholesale price.
    On my boat the breaker panel is on the port side in the salon bar. So I need about 8 or so feet of cable to get to the breaker panel from the bucket. I just bought a 75' white to replace my 5X' old yeller.
    As a side, I just finished installing new polished stainless, Buck Algonquin, hawes pipes. Now my electrical cord can go through the hawes pipes and not over the top. If anyone wants more information on that project we could start another thread and I can send pictures etc.
    David
  14. My Affair
    My Affair Member
    Mystic, CT
    Where is the Glendenning cm-7 unit? Thanks
  15. Davidoc
    The CM-7 is located above the cable bucket forward of the starboard engine. The cable dumps into the bucket from above. There are extension rollers along the starboard hull allowing the cable to be strung from the connector hole in the starboard cockpit. Take a look at this diagram. http://www.glendinningprods.com/gmp...-7/Cablemaster_CM_-_Installation_Examples.pdf. If you need a picture of my installation let me know.
  16. Davidoc
    Mine looks like the closed coupled diagram with the horizontal extensions
  17. My Affair
    My Affair Member
    Mystic, CT
    Dave, if you wouldn't mind taking a couple photos, I'd appreciate seeing how they installed that. I cannot picture where the basket would go unless it's in the storage area where the washer/dryer resides on the 46'.
    Thanks!
  18. mfan46
    mfan46 Member
    chesapeake bay
    I have a 89 46 also with the same set up as Dave it works well. I would recommend installing a remote control switch with a key fob that my wife loves.
  19. shawn
    shawn New Member
    old saybrook ct
    Your welcome to come down to Old Saybrook to see how I did mine. I have the 671Ti I put the bucket on the outside starboard side. I did not use the bucket they supplied , I used a cut plastic 55gal so the cable would lay in it better.
  20. Davidoc
    Will do. Will try to jump in there today. The storage container is in the engine room in the forward starboard location, to the right of my ac units and forward of my cockpit freezer compressor.
