Click for Ocean Alexander Cick to Clean Black Water Click for Abeking Click for Delta Click for Glendinning
ZF controller fault in gear
Discussion in 'Electronics' started by kev cribb, Mar 25, 2024.
  1. kev cribb
    kev cribb New Member
    Gibraltar
    Hi all
    Finally been out for a trial run after doing various bits on the engines. Boat ran fine for about 40 mins. After that went into neutral and suddenly ZF controller alarm goes off inside on the helm. Lost control of port engine could not put it into gear from neutral. Starboard engine fine so limped back to port.
    Now when you take control there is an audible alarm which will not stop and when you start the port engine it starts at about 1200 rpm but will not go into forward or reverse gear. Throttle lever will move but nothing engine wise. Throttle cable appears to be stuck at high revs when starting.
    Anyone had this before or got any ideas how to fix. Any help would be most welcome. I believe they are ZF MICRO COMMANDERS 91102 dual station
