Click for Ocean Alexander Click for Mulder Click for Burger Click for Glendinning Click for Northern Lights
xantrex link20 batt monitor problem
Discussion in 'Technical Discussion' started by pbekker, Aug 20, 2009.
  1. pbekker
    pbekker New Member
    the netherlands
    hello guy's
    i'm working on a refit of a 12m long sail boat
    my costumer buy for his boat the xantrex link 20 batt monitor
    everty is connectic on the right way
    i have used the orginal shunt that come with it
    the display is connect with a cat5 utp cable
    the only thing i changet is the shunt possision (and now it are 2 shuts inplace of the 2shuns with a connection on 1 side)
    orginale have to be in the negative side of the load
    and from there it split to the 2 negative's of the batt
    because of the cable onready on the boat and of the hard to get/mount of the batt i place the shunt in the possitive side before the load
    the charge is connect straight to the batt's
    all the nega are connectic at the batt straight
    (all orginal)
    the display show the batt volt but at the Amps it say thet the installion use 510A (always with or with out load)
    i have send this problem already to xantrex it self but the dont responce back to me already for 3 weeks
    i hope some one here can tell me what the problem is and what i need to do
    i also hoop i explane it little bit clear otherwise let me know and i try it agian
    tchau
  2. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    All of these battery monitoring systems are designed for the shunt to be installed in the negative (B-) return to the battery bank. So step 1 is to install the shunt correctly.
    A common mistake/problem is that the shunt has a battery side and a load/charging source side. The only connections to the battery side of the shunt are, you guessed it, the B- from the battery bank being monitored. All of the loads and the charging sources are to be connected to the opposite side of the shunt.
    I have installed dozens of these systems with no problems.
  3. pbekker
    pbekker New Member
    the netherlands
    hey charlie
    thx for the info
    but i already change the postion of the shunt and it work fine now ( before your replie)
    i took a good look agian on the cables close to the batt's and saw a easy way to make it good with out changing to mutch cable's
    at my old job i made also many of those monitorings systems but we made then differnt with a batt box and a batt monitor from mastervolt( at heesen yachts holland)
    this was my firts time that i to use this model/ brand
    some boat info;
    it is a very old sailboat (around the 20 years) made in the usa and the cable's and tubes are not so nice made and i came to late at the refit to make it all good loking (to bad i did it where i can )
    so thats why i try first this way but as you geust it did not work so good hahah
    but end of story it is all fix
    and working good
  4. YachtForums
    Your signature is been edited Charlie. Read our rules before engaging YF again.
