Click for Abeking Click for Glendinning Click for Abeking Click for Perko Click for Ocean Alexander
Windlass Issues - Maxwell Freedom 800
Discussion in 'Technical Discussion' started by love2speed, Jun 18, 2018.
  1. love2speed
    love2speed New Member
    Toronto, Ontario Canada
    I have an 06 Carver 41 CMY with original Maxwell 800 Windless and it started laboring just on the weight of the anchor.
    I always use a bridal to make sure there is no tension on the gypsy, I always motor toward the anchor during retrieval and never use the windlass to pull the boat.
    As of late it seems the windlass is laboring just to pull the released anchor out of the water. I'm stumped as to what the problem is as I just serviced the gypsy with proper marine grease last season and it was working great.
    Thanks in advance
    Check your battery cable connections and cables to and from the windlass. The motor may be going bad, but it might be something as easy as a cable connection or the cable itself.
  3. Pascal
    Indeed check the cables and connections. Look for loose cables or corrosion, at the battery, battery switch, breaker, solenoids and motor. Have you checked the battery voltage? Is it powered by a house bank or by dedicated battery? If dedicated is the charger on and working?
    Or, when was the last time it was properly serviced and greased up?
  5. love2speed
    it was greased up middle of last season when I replaced the pressure arm.
  6. CptnMaxwell
    CptnMaxwell New Member
    Auckland, NZ
    Answers above have some good suggestions.
    Most common cause of your symptoms (covers all DC windlass):
    1) Loose/Poor electrical connections resulting in large voltage drop at motor. In worst case will burn out windings.
    2) Gearbox damaged due to overload or lack of oil. Check state of oil - is there any, is it full of filings?
    3) Carbon buildup in motor. Remove motor rear cover and blow carbon dust out.
    4) Sticking brushes. Remove motor rear cover and check brushes can move freely and there is no damage to brushes.
  7. Flybull
    Flybull New Member
    Branson
    My money is on corrosion in the cabling/connections causing poor motor performance... although all good suggestions and must be looked at.
  8. Capt Ralph
    Sure could use an update?
  9. Flybull
    Flybull New Member
    Branson
    True dat.
  10. love2speed
    Actually I should have posted the resolution for this. It turns out the gypsy / clutch was loose, snugged it up and it resolved the problem
