Click for Walker Click for Burger Click for Abeking Click for YF Listing Service Click for Glendinning
Why are AB Yachts so cheap on the used boat market ?
Discussion in 'AB Yachts' started by AGav, Aug 15, 2015.
  1. AGav
    AGav New Member
    Italy
    Hello everyone, I am just starting to search for a used yacht in the 70/80 ft range in the med. I have read other forums, and clearly the preferred boats are San Laorenzo, Azimut, VZ, Maiora ets, or Mangusta and Pershing if you are looking for the sportier type. I have come across AB 78's which I understand are built by Maiora and the are quite cheaper on the used market than all the Others I mentioned. I quite like the look of them, but since I have learned that there is never a free lunch in life, there must be a reson for the lower price. Anyone own an Ab or have first hand experience of these boats? Thanks a lot in advance for all your help.
    low quality = low price.
  3. AGav
    AGav New Member
    Italy
    Thanks, that's the obvious reason, still quite hard to understand given that they are made by Maiora.
  4. olderboater
    I see two 78's for sale in Italy. One is a 2008 for $2.2 million and the other a 2006 for $958,000. It's only the 2006 that's exceptionally cheap but notice that the description says it needs some painting on the right side. That brings about many questions on that particular boat.
    One other reason is that the market for Jet's in that size range is limited.
  5. AGav
    AGav New Member
    Italy
    There's a 2005 AB 78 for sale in Monaco for 599000 euros with 500 hours on the MTU ngines and a 2001 75 foot for 390 k with 680 hours on the Deutz engines in Italy. Finally there's a 2006 78 foot with Cat engines with 550 hours asking price 860 k (specified negotiable). They are all asking prices and already seem really low. Are they really such terrible boats?
  6. olderboater
    You can't determine whether a price is low or not without seeing the boat. I know the one 2006 has some issues. That's the one for 860k Euro's or $958k. The 2001 for $434k is quite consistent with other comparable boats. Leopards for $423k and $412k, Azimut for $417k. These are all 75' 2001 low end express type boats. They aren't going to price with someone like Sunseeker and definitely not close to someone like Hatteras.
    I think we answered with the reasons above, but I'll add one and that is location of the boats.
    Which also builds low quality yachts.
  8. AGav
    AGav New Member
    Italy
    Thanks very much for your input, will have a look at the one in Monaco out of curiosity and will keep on searching other brands
  9. AGav
    AGav New Member
    Italy
    You are probably right, but the asking price on the secondary market is double the AB...
  10. Liam
    Liam Senior Member
    Malta
    Interesting that I was discussing this with an AB yachts dealer from Rome a coupe weeks ago, and the reason is the Jet drives and the market demand for this sub 80/90 feet is limited. Jet drives cost a fortune to install, and you need the hull for them.
    An AB Yachts 58 had a listing price from 1.8 million EUROS in 2008.
    On the handling side and workmanship I would consider AB Yachts a better product to a Pershing and Mangusta, and the engineer who did the hulls and founded the company Arnabodi was/is an expert in the area of the propulsion and hulls, in a military commercial level before he started up the company.
    I think the main reason of the lower used prices is that the design of the smaller AB Yachts (especially the 78) is not as much admired as that of the Pershing or Mangusta. Lets be honest Fulvio de Simoni, and Stefano Righini did a spectacular long term design project respectively on the two brands I mention above. That means that when you go in Saint Tropez with a Mangusta or a Pershing, each and everyone will recognize these boats.
    Size wise AB Yachts also offer less space then the competition, and some areas are a bit a catch like less wide side decks on both the AB Yachts 68 and 78, which was improved in later models. Also for example the most friendly AB 78 layout is the 3 cabin layout, fourth cabin version had a twin bunk berth to port side which is also a bit of let down for a 24 meter.
    That they have less space is not a bad thing, that means that AB is a boat build from the hull up, then the cabin down. That is what Arnaboldi said back in the days at Genoa, and I guess you gotta believe him. BTW I am not saying that a Pershing or a Mangusta is build cabin first, but I am sure there is some compromise in the design.
    Be also sure that you are looking for a real 78, as some brokers advertise the 72 Follia, 75 (72 with big bathing platform) as a 78. The real 78 is the one with the coach roof (HT) similar to that of 90. That cheap 78 around on YW seems to be a non completed never collected boat.
    Some years ago I was in Genoa boat show, and the only builders which would offer a test drive in rough seas where; Guy Couach, Italcraft, and AB Yachts (at the time AB Yachts was still not owned by FIPA).
    Fipa Maiora apart being expensive and fully custom is one of the few builders who AFAIK can built if you want a fully classed cross of Malta 20 meter or upwards. I guess you have to build low quality for that to be possible. Also up until the recession hit Italy the hardest (2011 till 2014) the 20 and 24 meters models where some of the boats who kept a very high price in the used market value here in the med. Not that this has always to do with quality to be fair.
    BTW other boats worth looking if high performance and sea keeping qualities are on the top list would be an Italcraft 70 Drago, and the Alfamarine 78.
    Kafue likes this.
  11. FeBo
    FeBo New Member
    Lake Como, Italy
    And: OTAM 80 (Hull designed by Fabio Buzzi), Baia 70 Italia, Baia 80 Atlantica, Sunseeker Predators
  12. Liam
    Liam Senior Member
    Malta
    I hope you are not serious in this quote as Sunseekers are always the cheaper of the price bracket, and quality is just above average in my book and it is a full blown production boat.
    2007/8s Predators are selling for minus 3/4s of a million Euros, atm. Even Azimut S sell more to this.
    I guess put a lot of shiny adverts everywhere and people start to believe it :(
    Give me an AB Yacht over a Sunseeker any-day.
  13. Liam
    Liam Senior Member
    Malta
    Sunseeker Predators are very over rated boats in my book, very nice in the harbours never to impressive in bad weather.
    Baia is among the best if you want surface drive boats, even better to a Pershing.
    Otam is more a direct competitor to a Magnum, and I guess that is another level all alone.
  14. AGav
    AGav New Member
    Italy
    Thanks so much for a thorough and comprehensive answer to my question, personally I don't find the design of the AB inferior to Mangusta or Pershing, but that is a totally personal opinion. I was very interested in what you said about handling in rough seas, I will try and test one in less than perfect waters. Once again thanks for taking the time to respond with concrete arguments and not just one phrase.
  15. AGav
    AGav New Member
    Italy
    That was my impression as a humble amateur...
  16. Liam
    Liam Senior Member
    Malta
    Agreed. In reality it is a less spectacular more conservative sport yacht design. Think of an AB Yachts as a woman with a some soft make up, unlike others which are full of it. ;)
  17. AGav
    AGav New Member
    Italy
    :D:D:D
  18. Capt J
    I wouldn't say that. I've run several Sunseekers. They all have rode great. I ran a new 73' Manhattan a year ago into 5-6' head seas and cruised right along at 26 knots, there wasn't an ounce of water over the rubrail in a 50NM run. I run an '07 62' Predator and it too is a great riding boat. Better than any other 60-65' express or MY. Baia build quality is very average. A friend of mine used to run an 80'.
  19. Liam
    Liam Senior Member
    Malta
    The 62 Predator is an okay hull. Have to disagree on the 73, good boat in following seas, just cuts it in head seas.
    You do not get wet in many of the Sunseekers that is true, but the slamming is a lot especially when waves start to become deeper.
    Depends on the age of the Baia, I was speaking about the combination of hull and surface drives.
    The yard was just a 5/10 in the installation (electrics) department prior to 2000, and improved after 2003/4.
    The 63 Azzurra would be one of the best hulls in that size for surface drives, and rough water handling, it even competes with a Magnum of similar size.
  20. muscled430
    muscled430 New Member
    Italy
    Ok.....Pershing is definitely not a boat well made, and if you try to navigate in rough sea you will destroy the boat. The quality of Baia is simply crap, but the hull is good.
    The Otam 80 has some issues, but not because Buzzi. He designed a spectacular boat, but then Otam added a lot of not necessary weights, and the boat does not perform that well.
    Mangusta....not a bad boat, not a bad hull, better made than the other I mentioned, but make sure you have a stabilizer onboard, other wise when at anchor you will be deeply sea sick, the boat rolls like crazy.
    AB has a great hull, and a quality superior than Azimut, Pershing, Sunseeker, Azimut and Baia.
    Now...let's go to the point : if you want a boat that has the space of a villa inside, well that boat will never be good on sea except the sea is flat. And if you want a boat that performs well on rough sea, then the space inside will be much less than a boat that looks like a summer villa. Why? For rough sea you need a deep V (best will be 24° deadrise from bow to stern, minimum will be 22°), and the bow must be thin, otherwise you will slam on waves. So the boats that go well in rough sea are slimmer, which means less space inside.
    Last comment : the design works when it is studied for the performances. A boat is an object that navigate, having a cool design that makes a boat not able to navigate in rough water is simply stupid....but humans are in general not very smart, and this is why Azimut, Ferretti, Sealine, Bavaria, Beneteau and many others keep selling yachts.
    bernd1972, Kafue and GPO like this.
