Click for Ocean Alexander Click for Abeking Click for Cross Click for Perko Click for Westport
White 100 amp cordset
Discussion in 'Technical Discussion' started by Jdow, Feb 16, 2019.
  1. Jdow
    Jdow New Member
    Massachusetts
    does anyone have a source for white 100 amp shore power cord? We need about 150’ of bulk cable.
    Glendinning
  3. Pascal
    Ward electrical in FTL
    Shop the two, it will be close and shipping charges (heavy wire) may be an issue.
  5. captholli
    captholli Senior Member
    In The Bilge
    Purchase at wholesale price from Cobra Wire & Cable Bulk cable cut to length.
  6. Jdow
    Jdow New Member
    Massachusetts
    Thank you, seems like no one lists it on there site. I have to call glendenning to order 2 cm8s Monday. I will check then. Thank you
  7. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Are you making a 150' cord?
  8. Jdow
    Jdow New Member
    Massachusetts
    No, 2) 50ft cords through cablemasters. Prob use 60-65’ each
  9. Capt J
    If that is the case, order the cords straight from Glenndenning with the ends molded on them. They come from Glenndenning in a 65' and 100' length, don't skimp on the length if you can fit the longer length in there (location and the size of your drum determine that). My price from Glenndenning was pretty reasonable, all of the times I ordered them. You also need to know if you have a 3 wire or 4 wire cord/system.
  10. Jdow
    Jdow New Member
    Massachusetts
    Great info thank you. I don’t believe I have enough height for 100’ cords but will measure and confirm.
  11. Pascal
    Also make sure you get tinned wire. Much more corrosion resistant. I ve replaced glendining installed cavle that were not tinned
  12. Jdow
    Jdow New Member
    Massachusetts
    Talked with glendenning, they do not have molded cord caps with 100 amp cord.
  13. Pascal
    Also beware that the Hubbel 100 plug doesn’t fit in the glend housing. I recently replaced one with a Marinco, much nicer design, which fits if you cut off the second clap. It is actually branded Menneke, made in Germany. Much better than the hubbell
  14. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    Call Wards, I got some white from them that had some blemishes really cheap, comparatively.
