Ready to go cruising? This 1975 Whitby 42 is for you. Experienced cruiser, East Coast, Bahamas and several years in the Med. The Whitby 42 Ketch is a Ted Brewer design with classic style and spacious accommodations. She features a center cockpit and mahogany interior with two staterooms. On deck we have a center cockpit with hardtop with full enclosure, wraparound seating and pedestal helm. Bottom was stripped and epoxy coated, recent bottom job showed no blisters. Sails & Rigging: · Main with Stack Pack · Genoa with foam luff · Profurl Genoa Furler · Mizzen staysail · Mizzen · Storm sail · Storm tri-sail with extra mast track · Spinnaker with sock · Spare main sail · Twin whisker poles · Spinnaker Halyard · Main Mast Steps Anchors: · CQR 45 lb, 50’ chain, 150’ rode · Bruce 60 lb, 100’ chain · Fortress FX-23, 100’ rode · Simpson Lawrence electric windlass Tanks: · Diesel: 210 gal (2 - Fiberglass 65 gal, 2 - AL 40 gal) o Keel tank is no longer in use · Water: 150 gal (1 – Fiberglass 70 gal, 2 - AL 40 gal) Engine: · Ford Lehman 4D254, 80 HP Electrical: · 5 KW genset · Magnum 3KW Inverter/Charger · House Bank: 6 Deep Discharge Golf Cart Batteries · Start Battery (new) · 4 Solar Panels, 130W, connected to two ProStar controllers Heads: · Forward, Lavac (new pump and seat assembly) · Aft, Raritan Elegance, fresh/raw water flush o Almost all black water plumbing is PVC pipe, no odor Water maker: · Offshore Marine Labs , 500gpd, pumps run but membrane was last pickled 10 years ago. Electronics: · Raymarine A98 Plotter with Depth Sounder · Raymarine Bluetooth Radar · Sitex AIS Transceiver · Icom 402 with DSC , Ram mic at helm · Navico Wheel pilot · There is a factory installed reversing pump plumbed into the hydraulic steering system. The pump works, just needs the electronics to operate it. · Sony AM/FM/CD sound system Fuel System: · Electric Fuel Pump (new) · Racor Filter Assembly (new) o Output of the pump goes to a valve manifold which allows fuel return to any tank. Allows transferring fuel between tanks and is also a basic fuel polishing system. Interior: · Mahagony, excellent condition · 2 Ocean Breeze A/C units, 12K and 9K · L-shaped settee on port side · Really ugly upholstered chair on starboard side · Nav Station Galley: · Under Counter Mini Fridge, 4 cu ft o The original built in fridge was a nightmare to access anything. Cut it out and replaced with a under counter 110 AC mini fridge on its own inverter. · Nova Kool 4.5 cu ft top loading freezer I removed the old propane stove and oven. Put in a Microwave/Convection oven to replace the propane oven. Currently has a single burner conduction cook top. Plan to replace it with a two burner propane cook top. Propane plumbing is still in place. Two 10 lb AL tanks, recently inspected and filled. · Slide out trash can Located in TX. Check out the link on the WhitbyBrewer WebSite: Mod edit: External Link Removed
