Click for YF Listing Service Click for Abeking Click for Abeking Click for CL Yachts Click for YF Listing Service
What is torque?
Discussion in 'Technical Discussion' started by tirekicker11, Nov 20, 2010.
  1. tirekicker11
    tirekicker11 Senior Member
    SE Asia
    I have been reading about torque and reduction gears and I don't understand it at all.
    I thought that the idea was to make a propellor turn as fast as possible in order to displace as much water as possible but now I read that the gearbox reduces the revs from the engine in order to give more torque to the prop.
    I have been looking everywhere but I can't find an answer I understand.
    Torque is 'turning force' as in the force or pressure you use to turn something. In different applications bolts, nuts, even jar lids, etc. have to be tightened with a certain amount of pressure to keep from backing off. A torque wrench measures the pressure applied. A prop needs a certain amount of pressure to turn through the water and push the load (boat). Reduction gears reduce the turning speed of the shaft as opposed to the cam to increase torque. This explains it pretty well.
    http://www.teamdavinci.com/understanding_gear_reduction.htm
  3. tirekicker11
    SE Asia
    Thanks NYCAP but that's the part that I do understand.
    What I don't understand is why you would reduce the rev's (of the prop) in order to gain torque. What I thought is that you want the prop to do high revs in order to provide speed.
  4. NYCAP123
    Ever drive an underpowered, manual shift car up a steep hill? If you hit it in high gear doing 60 you'll soon be doing 30 unless you downshift. Your transmission is a reduction gear, in fact multiple reduction gears because cars experience multiple pressures (conditions). Boats generally only need one because the pressure is generated by the weight of the boat (load). Different boats will need different ratios to handle different loads. A speed boat's load is far different from that of a tug although (theoretically) the could use the same motor.
  5. tirekicker11
    SE Asia
    Thanks NYCAP,
    That explains a lot.
    So in theory it might be possible that certain designs don't use a reduction gear at all?
  6. NYCAP123
    Sure, maybe like a hydroplane that's going for maximum speed; pushing very little wait against almost no resistance and that doesn't mind blowing an engine in that pursuit if it over-revs.
  7. tirekicker11
    SE Asia
    Got it, thanks NYCAP!
