Click for Nordhavn Click for Nordhavn Click for Westport Click for Ocean Alexander Click for MotorCheck
Water tank sender unit on the 46
Discussion in 'Post Yacht' started by Davidoc, Nov 25, 2021.
  1. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    The sender unit is on top of the port tank just behind the engine room wall in the cockpit. It is leaking pretty bad when we fill the tank. I can't quite see it. Does anybody know if it is shallow enough to be lifted out the top to be fixed. It has three screws and I'm guessing an o-ring seal. The gauge still works fine. The vent hose to the cockpit is clear so I don't think I blew it up on an overfill. That hose used to overflow fine. Anybody change one?
  2. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Could also be the fill line /pipe going into the tank that’s leaking.
    That’s was leaking along with the sender on my Ocean Yachts tank.
    lucky my tank is easy to get to.
    Sorry I can not help you on how to get to yours.
    You are a pretty sharp guy, I’ve read your Post…posts. Lol
    And I’m sure you will find a way to get it done. Sure would be nice to here from someone who’s tackled this already.
  3. Davidoc
    Three screws? Usually 5.
    Davidoc likes this.
  5. leeky
    leeky Senior Member
    Florida
    Hey, Davidoc, if you meant to post something in your post #3, you'll have to try it again. Make sure you're not using white text color.:D
  6. Stainless45
    Stainless45 Active Member
    Post 46 Long Island NY
    My gauge has never worked and I did not know where the sender was so thanks for that :)
  7. Davidoc
    Thanks. No trace of leak while filling. Only when just full
    One of the guys know about this. They'll post something next week. Thanks
