Click for Nordhavn Click for Delta Privacy Matters Click for Abeking Click for Glendinning
Water separating filters
Discussion in 'Technical Discussion' started by dennismc, Jul 13, 2015.
  1. dennismc
    dennismc Senior Member
    Vancouver BC
    The manufacturer cannot give a statement as to the service life of this item, is not a Racor, when would expect to change these ? are drained on a regular basis with no sign as yet of water.
  2. K1W1
    That is like asking How long is a piece of string.
    The life of the filters will depend on how much fuel passes through them and how much material was in that fuel that got removed by the filter, the water sep part should be able to be drained and may have a clear bowl so you can see what is in there.
  3. dennismc
    Vancouver BC
    The mfr says they only make the filter and cannot recommend a change interval. Their tech dept is doing some more investigating.
  4. K1W1
    Fit a vacuum gauge to the engine side of the filter, replace the elements , run the boat and make a note of the vacuum, when it gets to a good negative pressure replace the filter.
  5. menkes
    menkes Member
    Aretsou, greece
    I would say evry engine service (200-300 hours).
    It's cheaper then engine overall
  6. K1W1
    On a main engines I run the primaries for 1000 hrs or on condition, on Gensets 500hrs or on condition.
