Click for Glendinning Click for Perko Click for JetForums Click for Ocean Alexander Click for Abeking
Water pump leak
Discussion in 'Ocean Yacht' started by Boomer, Feb 3, 2020.
  1. Boomer
    Boomer Senior Member
    Seminole
    Hello all....did pressure test on the coolant side of the motor and all was well after the rebuild...during test run on the motor I noticed an occasional coolant drip from the fresh water pump...appears to be coming out of the shaft area...I assume rebuild is needed..are the bearings pressed in or is just a simple rebuild job with gaskets and seal rings? Schematic doesn't notate if the bearings are pressed in or not
    Not sure, most DD shops could answer your question.
  3. Boomer
    Seminole
    How can you tell if it is high capacity or are all J&T high capacity pumps?
    How much pressure did you pump up? Max testing pressure is 8 psi.
  5. Capt Ralph
    Some pumps are field servicable. Your dad shop should be able to help.
  6. Boomer
    Seminole
    It was 5 or 6
  7. Capt Ralph
    Oh DD shop. Not dad shop.
  8. Capt Ralph
    6 is good. How much time on the leak?
  9. Boomer
    Seminole
    I had about 9 hours sleep...lol...an hour seriously
  10. Capt Ralph
    Go for a run. Could just be some trash on the machanical seal.
  11. Capt Ralph
    I'm in Gainesville now. Big day tomorrow. I can't look up beans on this **** phone.
    Did we already talk about this pump?
  12. Boomer
    Seminole
    Negative..you did ask if it was high performance or regular but that was as far as we got on it as my overheating problem happened gradually over the summer...
  13. Boomer
    Seminole
    Where do you buy these reman pumps? JT wants $315...saw them on ebay for $180 hi flow or $100 regular flow...how do I know which one I have?
  14. Boomer
    Seminole
    Good luck with the hip tomorrow!
  15. chesapeake46
    chesapeake46 Senior Member
    Second that... Good luck tomorrow
  16. Capt J
    Call a DD shop with serial number on your engine and they should be able to look it up.
  17. T.T.
    T.T. Senior Member
    S.F.
    good luck RC, after care and PT will be your job for a bit!
  18. Boomer
    Seminole
    Thx
  19. Capt J
    That being said, I'd be really hesitant of buying a rebuilt one off of ebay. Just think of all of the labor of dropping the coolant, adding coolant, taking all of the crap off of the front of the motor to get to it, etc. etc. to possibly save $100 or so.
  20. Boomer
    Seminole
    FYI...Napa has these water pumps in stock, hi capacity for $92! Just passing along what I have found with a years warranty
