Click for Perko Click for JetForums Click for Walker Click for Mulder Click for Glendinning
Water in transmission
Discussion in 'Technical Discussion' started by breakaway1, Apr 18, 2019.
  1. breakaway1
    breakaway1 New Member
    NH
    I noticed water in my transmission fluid. I'm good about checking fluid levels I just sent the cooler out to be tested. My question is. Can this transmission be flushed out has anyone had this problem and had success flushing out and running the boat.
    What clutch mfg/model do you have?
    Yes, keep changing the fluid/oil and it can be fine.
  3. Beau
    Beau Senior Member
    Beaufort, NC
    Depending on how much water is in the tranny you may be able to run a tube to the bottom of the sump and pump it out also. Don't forget to empty the existing oil filter and then replace with new when you've completed flushing.
  4. gsholz
    gsholz New Member
    PDX
    I had to flush three times (+ bring it up to temp in between) to get rid of all the emulsified water in the transmission. No long-term damage as far as I could tell.
  5. Capt Ralph
    Also, its usally better to replace the oil cooler than repair it.
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Keep a watch on it, and even if it looks clean after a few runs, I would change it at least one more time with the filter
  7. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    How did water get in there in the first place ?
  8. Beau
    Beau Senior Member
    Beaufort, NC
    . If you have twins you may consider replacing both coolers if that was your problem.
  9. Capt Ralph
    Other than the clutch sinking (submersion), It's the oil cooler.
  10. bayoubud
    bayoubud Senior Member
    Florida
    On a previous boat had high sodium on a gear oil analysis, the cooler failed the pressure test. Mechanic replaced the cooler and changed oil/ filter, said to retest at 50 hrs. Gear was ok, caught the cooler leak in time.
  11. cleanslate
    Cherry Hill, NJ
    Ahh ...as usual learned something new again on YF...I did know there was a trans cooler somewhere on my DDs , but forgot about them and their purpose and the other reason to check the oil other than just for the proper oil level.
    My trans dip sticks are right in my face easy as can be to check , now I'll put them on an "always" basis.
  12. Beau
    Beau Senior Member
    Beaufort, NC
    Check the same time you check your oil- that should be every time you start them up even at the dock. You'll never know your oil bled out thru a hose or metal failure unless you look.
    Most manufactures also recommend a filter and fluid change every 200-250 hour or 2 years, I believe. My ZF's do. Mine use straight 30w
  13. Capt J
    Or, if the gear lost oil, you'll get out of the slip and have no forward or reverse on one engine and a major OH NO moment.
