Click for Walker Click for Delta Click for Burger Click for Nordhavn Click for YF Listing Service
want to install AC in my carver 3207 ac
Discussion in 'Carver Yacht' started by js_318, Mar 20, 2011.
  1. js_318
    js_318 New Member
    Barrie, Ontario, Canada
    Got my boat last year and found that I need AC...:)
    To all carver 3207 ac owners, can you tell me where the put the unit on your boat?
  2. Fireman431
    Fireman431 Senior Member
    East central Florida
    I don't have a 3207 (I have a 374 Voyager), but I can tell you that most units are installed under one of the seats in the dinette, under the base of the master berth, or in an inter-wall space of a companion way. I don't think the location of your installation is going to be that difficult. The tough part will be peeling apart the interior finsih work to run the duct work.
    The other side of this coin is tha tyou may be able to install the exhaust duct in the base of whatever housing you find for your A/C.
    Look at some other 3207's (or other vessels that size) and see where they put theirs.
  3. js_318
    js_318 New Member
    thanks for your reply...
    I am in Ontario Canada and not all 3207 have air...but i will search on
  4. mjkkemper
    mjkkemper Member
    Grosse Pointe Farms, MI
    my 86' 3207 the compresor/evaporator is located in the galley between the refrigerator and the sink
    The pump is in the engine room between the port engine and the gen set
    The rear air is located under the port side bunk aft next to the trim tab pump
