Click for Delta Click for Cross Click for YF Listing Service Click for Ocean Alexander Click for CL Yachts
VOLVO PENTA EVC error codes
Discussion in 'Engines' started by Bokker, Jul 30, 2020.
  1. Bokker
    Bokker New Member
    Utrecht
    Hope someone can help me: I have a 2012 VOLVO PENTA D4-260. Ten seconds after starting I get this error:
    MID 128; PSID 50 (sometimes 53); FMI 2 (sometimes 1). The engine runs smoothly; filters were changed 20 hrs ago.
    Many thanks!
    I believe those codes are indicating low coolant and low fuel pressure. Both normal situations at start up. Is this a new situation or could it be normal like your oil, coolant and check engine lights going on when you start you car?
  3. Bokker
    Bokker New Member
    Utrecht
    Thanks, it is a new situation, unfortunately. I've done a google session, and what I think now is a faulty sensor.
  4. NYCAP123
    That would be multiple sensors which would lead me to something with the ECM.
  5. NYCAP123
    That would be multiple sensors which would lead me toward something with the ECM. I suggest you send a PM to Fishtigua. In case you have problems with doing that I'll send one to him alerting him to this thread. Hopefully he'll be able to give you some insight.
    Done.
  6. Bokker
    Bokker New Member
    Utrecht
    Thanks!
  7. alvareza
    alvareza Senior Member
    Scituate MA
    Maybe a loose harness connection.
  8. NYCAP123
    I'd expect it to happen more than just when he starts with that.
