Click for JetForums Click for Mulder Click for Ocean Alexander Click for Burger Click for Cross
Volvo Penta D3-110, Warning check EVC system.
Discussion in 'Engines' started by Phil Boniwell, Aug 21, 2016.
  1. Phil Boniwell
    Phil Boniwell New Member
    Weymouth
    Hi everyone,
    Wondering if anyone can help.
    Ocqueteau 645 steaming along at 2750 revs when tachometer beeps and reads 'warning check EVC system', Tachometer falls to zero but revs remain the same. I come down to tick over and switch the engine off, then start up again whereby the tachometer starts working again and the warning disappears. I bring her up to 2000 revs where she sits happily for an hour until I increase up to 2750 rpm then within 30 secs tachometer beeps and warns check EVC and falls to zero(revs remain the same)
    My EVC only monitors 5 conditions, Engine hours, Turbo pressure, Coolant temp, Voltage, and RPM.
    Local agent here in Weymouth put Vodia tool on and it read unidentifiable fault, they said check all EVC connections (which I have done,including the two engine fuses) but to no avail.
    I have run the engine out of gear for 15 mins at 3000rpm and no warning shows so my eyes are turning towards turbo pressure or coolant temperature.
    Any help would be greatly appreciated guys...thanks.....Phil
    Well, what does the coolant temperature read when you're in gear at 2750 rpms for a while? When was the last time you've changed your raw water impellor? How's your coolant level? How many hours/years does the heat exchanger have on it without being cleaned?
  3. Phil Boniwell
    Weymouth
    Thanks for prompt response Capt J,
    The boat has just had a full service from Volvo,all filters oils impeller and coolant were replaced, the coolant reads 86 degrees C at 2750 rpm.
    The EVC alarm would tell me if the coolant were to hot,or indeed if there was a problem with the engine, but the engine runs beautifully'
    The problem I have is with the EVC system itself, it reads 'Warning check EVC system'
    I'm guessing you have a power or ground issue to the EVC and also why the tachometer goes blank. I would check power and ground connections on the harness. But, barring anything obvious there, it sounds like you're going to need to get a Volvo computer hooked up to it (dealer).
  5. Capt Ralph
    Volvo just did the service and you get the error?
    Any EVC or ECM updates preformed? How deep was their service?
    Inter-cooler, starter or alternator repairs? Battery connects cleaned?
    Think you need to call the Volvo tech back out if the error happened RITE after their service.
    Were they real Volvo techs? They have the LapTop to talk to your machine?
    It could be so easy as the sender or wire to it was bumped (flywheel mag pick up?).
  6. Phil Boniwell
    Weymouth
    Thanks guys for your help,
    I'm from a marine engineering background so I'm pretty clued up on marine diesels and how they work.
    My snag is the electronics of the EVC. The snag was there before the service, they connected their Vodia interrogation tool and it showed no faults on the engine, just an unidentifiable fault on the EVC system.
    The problem I think is electronic, yet related to the change in the engine state as it approaches full power, which is what leads me towards temperature and/or pressure. It is not a mechanical problem because the EVC would register a fault to that effect.
    So in short the engine runs perfectly, it's the EVC that cuts out as the engine gets close to full power, it's almost as if an EVC sensor is working loose through vibration or expansion via temperature rise.
    The most relevant information is--
    The engine runs flat out at 3000 rpm out of gear with no problem.
    The engine runs in gear at 2200 rpm with no problem until I increase to 2400 rpm when the warning beeps within a minute.
    Grrrrrr!
    I will check out your suggestions ref earthing points etc.......Many thanks again
  7. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Depending on which model of D3/EVC you're running, there are a few things to check.
    In the air filter/inlet there's an air mass sensor that fails often, can really screw-up your day. Hard to trace just with Vodia. You can buy the Bosch one online for £20 rather than the £80 Volvo wants.
    The other one is on the turbo side. The variable vanes can stop working properly for no reason, hence the drop in revs.
    Just a couple of ideas to try.
  8. Phil Boniwell
    Weymouth
    Cheers Fishtigua, that is great information, I checked out the turbo vanes and everything seems fine there.
    I'm sure the tachometer dropping to zero is an attention seeker programmed in to to do just that, the engine does not miss a beat when the warning goes off.
    I'm sure it is related to 'under load' conditions....thanks again for your help, I'll keep you all posted if I find the snag.
  9. Amund litlabo
    Amund litlabo New Member
    Stord
    Hi, I have the same problem with a D3-150, 2014 model! Volvo mekanics cant find the problems have tryed new evc brain, nothing helps!
  10. Amund litlabo
    Stord
    Any news about this problem?
  11. Phil Boniwell
    Weymouth
    Hi Amund, sorry for late reply but no, nothing has changed.
  12. Graham B
    Graham B Guest
    Phil, I just spoke to the Chief Engineer out here on the survey vessel, he is leaning towards the earlier comment from Capt Ralph "It could be so easy as the sender or wire to it was bumped (flywheel mag pick up?)". I don't have the drawings out here with me, but it would make sense that the engine vibration off load differs to the vibration on load or clutched in. We should check if it's a flywheel or shaft pick up and then check the sensor is fixed tightly or hasn't been knocked out of kilter or loosened somehow? Apart from that, the single battery option could be the way to go for a trial (post Covid) :-(
  13. Phil Boniwell
    Weymouth
    Hi Gase, I’ll check where the RPM sensor is located and check that wiring back to the EVC brain. It’s worth a try because the snag is related to engine revs.
    Thanks for keeping on it!
  14. Graham B
    Graham B Guest
    Ok Phil no worries...he spoke to me again this morning after a good think about it and also suggested reverting back to the single battery option or at least how the boat was when it was delivered. ;)
  15. Phil Boniwell
    Weymouth
    I think we’ll do that before anything else
  16. Phil Boniwell
    Weymouth
    Hi Amund, all this time has passed and I still have this bloody EVC problem, did you get yours fixed?
