Click for Northern Lights Click for Perko Click for Ocean Alexander Click for JetForums Click for Westport
Volvo IPS improvements
Discussion in 'General Yachting Discussion' started by FishForFun, Mar 25, 2021.
  1. FishForFun
    FishForFun New Member
    Atlanta
    Looking for some guidance regarding the IPS drives. I am in the market for 3-6 year old boats in the 50-55 ft range, so probably a series 2, IPS 950. It seems many, if not most, of my choices have the Volvo IPS drives with Riviera being a top choice.
    I have read many good and bad reports on these. It seems the early models were most prone to failure from water intrusion. What year models can I assume have an updated IPS with improved reliability?
    I see where the latest 2019-20 have some additional self monitoring capabilities and reduced service intervals that seem attractive. Should I just bite the bullet and go new for this important aspect of ownership?
    Thanks for any input.
  2. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    From what I have been reading over the years pods can have a very limited life (certainly not decades) and replacing them is part of the "pay to play" equation. If the idea of shelling out a sizable chunk of cash in the course of "regular maintenance" is not appealing, I recommend straight shafts. Props, struts and shafts are $$ as they are. I would not own them on a limited budget.
    Dealership likes this.
  3. NYCAP123
    Why are you looking at IPS? If you're looking in that size range I assume you have experience in boat handling. I like IPS, but I view them as something to bring people into boating. Once over 50' I agree with Ocarvan that with their maintenance it's a case of diminishing return and would recommend shafts, especially if you use your boat a lot.
  4. Oscarvan
    Chesapeake Bay
    Not sure they are meant to "bring people into boating"...... They provide a level of manoeurability that is unequaled. There is a reason they build tugs with them. But, there is a (large) price to pay for this, and most of us do fine without it, on the water and in our wallet. Same reason most of us don't have $50,000 sound systems on board.
  5. Capt Cole
    Capt Cole Member
    Pittsburg CA
    If IPS is your preference, definitely go for newer version. Older units required haul out to change fluid. Newer models can be serviced from the the engine space. I can't speak to longevity but I can say performance with IPS is a plus.
    You may also want to contact your insurance company to compare the same boat with shafts vs IPS. I wouldn't be surprised if insurance premium were higher with IPS; only because they are very expensive to repair or replace if severely damaged.
  6. Oscarvan
    Chesapeake Bay
    I wonder if a really hard grounding at speed will leave them behind and a sizable hole, or two, in the hull.
  7. mapism
    mapism Senior Member
    Sardinia
    Don't mix the sacred with the profane.
    Azimuthing propulsion on displacement vessels has been around for ages, but comparing the products of Thrustmaster and the likes to IPS is akin to compare, well, a tug with a pleasure boat.
    The reasons why the former needs steerable thrust make the reasons for IPS in the latter laughable, in comparison.
  8. Pascal
    they are supposed to shear off without allowing water in.
  9. Oscarvan
    Chesapeake Bay
    Key words.... "supposed to".... Anyone know the test pilot? :D
  10. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    I was a Volvo dealer for many years, still prefer a shaft and rudder.
  11. NYCAP123
    A hard grounding runs the gamut from expensive to devastating. With shaft drive you may bend a prop or you may rip the shafts, shaft logs, struts and rudders out of the boat. In which case you sink. With IPS you may bend a prop, damage the lower unit inside or out or rip the drive unit off. In which case it's designed to seal itself. Pick your poison. The amount of fuel savings and speed increase with IPS is debatable. Where IPS shine is around the dock. It makes maneuvering easy. Where shaft drive shines is in the cost of annual maintenance. That's why I credit IPS with being good for bringing new boaters in and making them comfortable with a bigger boat. That's also why I put the cutoff at around 45'. Once someone is looking at over 50' I expect the buyer to have enough experience to be comfortable docking their vessel. Since experienced boaters tend to avoid hard groundings it then comes down to the cost of the IPS and its annual maintenance.
    Rickfisher likes this.
  12. mapism
    Sardinia
    Very sensible summary NYCAP, I couldn't agree more.
  13. FishForFun
    Atlanta
    Thanks for the perspective on IPS vs shaft drives.
    However, my question has to do with dating which years (if any) the improvements in the IPS drives made them more reliable and a reasonable option in used boats.
    Unfortunately, a significant number of boats on the market have Volvo IPS, so rather than rule them out entirely, I want to better understand which years and series to avoid.
    Also perhaps a perspective on lifespan expectations before a major overhaul is likely.
    Again, thank you for your expertise,
    FFF
  14. NYCAP123
    Not sure when what upgrades were done but I think you'll find that older IPS units have either been upgraded or not exhibited problems, and that can generally be verified through maintenance records. So I wouldn't put the year as a deal breaker. I think Fish (who responded before) or AMG would have the best info on when upgrades were initiated. Maybe send them a PM about it.
  15. mapism
    Sardinia
    I very much doubt that anyone will be able to confirm you some specific dates defining the border between the good, the bad and the ugly.
    Changing/updating/improving engine components is something that the manufacturers do constantly, also behind the scenes, so to speak.
    You can even find two identical engines, both built in the same year, but possibly in different factories and/or with different parts, eventually proving more or less reliable.
    In the case of VP for instance, even if I can't remember exactly which engine model was involved, they used either Bosch or Denso injectors+HP pumps. Theoretically identical engines, but after several years the Denso ones became an owner's nightmare, while the Bosch ones were fine.
    Anyway, you are in a lucky position now, not having an IPS boat yet: just avoid them all, it's that simple! :D
  16. f3504x4ps
    f3504x4ps Member
    Cape Canaveral, FL
    You want version D or newer, which I believe is 2012 or newer. A, B, and C had more issues. The steering/sealing ring, prop shaft and carrier seales were upgraded on version D. Older versions the strainer would leak. Stick to D 2012 and newer.
  17. Slimshady
    Slimshady Senior Member
    Lighthouse pt
    I had 2014 version E and still had lots of issues. Not a motor to buy IMHO.
  18. Dobeck
    Dobeck New Member
    Out and about.
    While this report is nearly 11 years old, it is an interesting deep dive into the failure of the IPS fusible link that resulted in a rapid sinking.
    https://turvallisuustutkinta.fi/mat...tutkintaselostus/c32010m_tutkintaselostus.pdf
    No boat is unsinkable and no pleasure boat should be expected to survive being run up on rocks at nearly full speed, but this one particular instance where only the pods struck the submerged obstacle, yet did not shear highlights the importance of a solid hull with sound structural members. My question, were I considering a boat with pods, would be whether a surveyor would be able to detect similar structural inadequacies without destructive testing, or if that's even a concern within the year range I were looking at.
  19. NYCAP123
    Sounds like that skipper was trying very hard to destroy his boat. What do you think would happen to a conventional drive if you hit a rock with its running gear at WOT? Good chance you'd pull the running gear and the rudders out of the boat, and maybe the bottom off. I think what most buyers have to ask themselves is how often they intend to run full bore into rocks. If the answer is even once maybe they should stay on land. If the IPS drive breaks off and seals your boat you're probably getting back in the water a lot faster than if the running gear gets ripped out no matter which drive system you're using. There is no perfect system, and antidotal evidence can be found to bolster any view. (I know of a boat right here on Great South Bay that tore its running gear out of the boat and sank it after hitting the sand bottom there.) IPS isn't marketed as an indestructible system. It's marketed as making close quarters maneuvering easy. Their self-sealing technology is amazing to me even if it doesn't work 100% of the time.
  20. f3504x4ps
    f3504x4ps Member
    Cape Canaveral, FL
    Agree, I was answering the OP's question.
    Now for me, I like several boats but they only come with IPS, no matter what I would never purchase one with IPS or Zeus. That may limit my boat purchase, but not interested in spending 100k for new pod if the trans and clutches go bad from water.
