Click for Nordhavn Click for YF Listing Service Click for Northern Lights Click for YF Listing Service Click for Burger
Volvo D6 IPS 500 low rpm
Discussion in 'Engines' started by trikala, Aug 18, 2010.
  1. trikala
    trikala New Member
    thessaloniki
    is it ok to run D6 Volvo at low rpm for reduced fuel consumption and safety for long period of time ie 1200-1500 rpm? Is the wear and tear of the supercharger more at low rpm vs the the high rpm 2900-3100 (where the turbo kick in)? Length of the boat 39.
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    That might be best answered by Volvo.
  3. savitt
    savitt New Member
    lighthouse point
    Well after owning a boat with IPS 500, and now have IPS 600's I just found out I have never even used the superchargers....The Volvo tech was just out on my boat and I showed me how they work.
    They only come on momenterly when needed, you can test this yourself...from idle just gun the throttles, the SC come on to bump the rpms up to the turbos, (this only takes seconds) you'll actually hear and feel them.
    I like you thought they were always on at low rpms, I never push it hard so the computer never switched them on...so like me chances are you never used them either.
    so the answer: is you are not using them at low rpms.
    also make sure you have a volvo tech update the software, they have upgrades with in the last few years.
    BTW this is my first post, I just had to register to help, since I just went thru this.
