Click for Westport Click for Walker Click for Northern Lights Click for Cross Click for CL Yachts 99X
Volvo D-12 engines
Discussion in 'Engines' started by Terriseefeldt, Jun 14, 2022.
  1. Terriseefeldt
    Terriseefeldt New Member
    Florida
    what is the proper operating temps for twin 715 hp Volvo D-12. Engines?
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Water in, water out. Why are you asking?
    Ex-Volvo guy here.
  3. Terriseefeldt
    Florida
    When we are running around 20 knots the engines are getting up around 197-198. We had the heat exchanger acid washed, but it’s still hot. Impeller is okay too
  4. mapism
    mapism Senior Member
    Sardinia
    Speed as such doesn't tell much.
    Depending on the boat, you might be either at max rpm and full load, or at a relatively low rpm/load, or anywhere in between.
    Anyway, full rpm/load aside, coolant should be about 10 deg lower than that, by and large.
    Beware of acid washing heat exchangers, that only cleans the raw water side but the fresh water side might still be dirty.
    It takes a full removal for a proper job, the rest is just corner cutting.
  5. Sea Gull
    Sea Gull Member
    CT
    I run D13-1000s. Since new they run at 189-190 at cruise speed. Never seen them higher than 190, even at WOT.
  6. Fishtigua
    Guernsey/Antigua
    And the water inlet is how big while up on the plane?
  7. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    is this a new issue? When did it start? Any changes other than acid wash of the H/E’s? What temps did they run previously? What load % are you at when seeing these elevated temps? Do temps climb further with more throttle?
  8. mapism
    Sardinia
    It's fair to expect that the builder fitted a large enough inlet, I reckon...
    ...and I can't think of any reason why that should have been changed/restricted afterwards.
    OTOH, it would be interested to hear the answers to Dockmaster's questions.
  9. Fishtigua
    Guernsey/Antigua
    The inlet and outlet of cooling water is a pretty basic plan for most of us.
  10. Scott M
    Scott M Member
    Annapolis, MD
    I ran a pair of D-12 800's for many years and they always ran 183-85 at 80% load. At WOT, I would see 190, but nothing as high as you are seeing.
  11. Fiammetta42
    Fiammetta42 Member
    Liguria Italy ( boat )
    Use a hand held infra red gauge on the thermostat house or HE body to determine if the sensors / dash instruments are accurate .
