Click for Mulder Click for Furuno Click for Walker Click for Ocean Alexander Click for Cross
Vinyl Headliners stains
Discussion in 'General Yachting Discussion' started by Dave Stranks, Apr 30, 2014.
  1. Dave Stranks
    Dave Stranks Member
    Coal Harbor Vancouver
    I have sectional ceiling panels in the living room of cream white vinyl and at the joins. I have black - grey spotting in a few places. Tried washing with soapy water but it seems to be in the material. I'm in a wet climate (Vancouver) and sort of guessing it maybe the staples holding the vinyl have sweated out.
    I have seen this happen even with galvanized and stainless on leather furniture at the cottage.
    Replacement would be a big job. Maybe touch up painting or stain
    Any ideas
  2. dsharp
    dsharp Senior Member
    lake jackson, tx
    If replaced make sure they use monel staples. You may want to look on the net for an upholstery forum. There's one in particular that has a few members that do bimini's and boat cushions. I can't recall the name offhand
    If it's spots, it generally is mold that is on the back side of the material and coming through the front of it. Which will show as grey or even a red wine color a lot of times. Staples will generally show as a rust color. If you can get to the back side, spray it with a marine fabric mildew remover. I would highly recommend using a de-humidifier to get your humidity down. Getting your humidity way down may cause them to go away on their own.
  4. NYCAP123
    My first thought was mold or mildew as well. Most modern air conditioning controls have a dehumidifier setting. Use it always when off the boat.
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Auto body and paint supply shops sell vinyl dye in spray bomb cans. They cover very well and look good as well. You would have to remove the panels and do them all. But it's cheaper and easier than replacing the vinyl.
  6. Dave Stranks
    Dave Stranks Member
    I'll check out the auto stores
    If the spots are from mold on the backside of the material they will come through the vinyl dye as well. I also don't recommend using the vinyl dye if your vinyl is in good condition otherwise because it changes the texture of the vinyl (makes it stiff) and also will eventually peel off.
  8. Capt Bill11
    While I agree if your vinyl is in good condition otherwise and you can get it clean and remove the spots I wouldn't bother dying it. But for what it's worth, I've done a number of exterior cushion sets with spray vinyl die and I've never had it peel, never had it stiffen the vinyl that I noticed and spots and stains did not bleed through. The dye, at least not the ones I've use, is not like a paint that sits on the surface of the vinyl, it seems to soak in like the name dye would imply. I used the Dupli-Color and SEM brands as I recall. And since they are designed to be sprayed on very flexible surfaces like shifter boots, they don't crack or peel.
    But as they say, YMMV
