Click for Abeking Click for Ocean Alexander Click for Abeking Click for Nordhavn Click for CL Yachts 99X
Viking 63 Air draft
Discussion in 'Viking Yacht' started by Anthony hall, Jun 26, 2022.
  1. Anthony hall
    Anthony hall New Member
    Texas,Florida
    Does anyone know what the "Air Draft is on a 1991 Viking 63. With full Fuel Tanks and no Radar arch will it fit under the 19' 6" Chicago bridge?
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Call Viking?
    -Chris
  3. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Bridge clearance 21.5 ft.
    Google is your friend
  4. Nevin Taylor
    Nevin Taylor New Member
    Washington DC
    If you take of the Bridge (5-bolts on each side) you will have 18ft 9in air draft with full water (120gal), waste (60gal), fuel primary (1070gal) and alternate (250) fuel tank. That is 1400 gal total at 8lbs a gallon. So if your vessel has less capacity, multiple the total less gallons by 8lbs per gallon and figure about half an inch per 500gal less capacity. Taking off the bridge will require four people to do it safely. Best of luck.
  5. Anthony hall
    Texas,Florida
    Thanks Nevin! My 63 has a fold-able rear arch so I should be fine with full fuel ,water and tender for the Chicago bridge. Cheers Anthony Hall
