Click for Cross Click for Mulder Click for Ocean Alexander Click for Westport Click for JetForums
Van Lent 102 meter (334 ft)
Discussion in 'Feadship Yacht' started by davidwb, Jun 30, 2012.
  1. davidwb
    davidwb Senior Member
    Holland.
  2. Telemachus
    Telemachus Senior Member
    Chicago
    Does anyone know if those twin, tubular projections toward the aft end are rough-outs for azipods?
  3. AlfredZ
    AlfredZ Senior Member
    Landlocked in Europe
    I think they are rudder ports because you can see the propeller channels.
  4. Milow232
    Milow232 Guest
    No, more thank likely for conventional rudder posts.
  5. Telemachus
    Chicago
    So, azipods are found on flat-bottomed hulls? These channels are for the purpose of cavitation, right? Traditional screws work better with these channels, I take it?
  6. AlfredZ
    Right on the money! Pod drives require open water flow because they rotate and should not be obstracted, while as you mentioned for the purpose of cavitation propellers require running channels to do their magic.
  7. Telemachus
    Chicago
    Thank you! I felt so good from that affirmation, I almost high-fived myself. However, I quickly realized it would deprecate what little dignity I have left.
  8. Yacht News
    The hull looks good!
  9. davidwb
    Holland.
  10. davidwb
    Holland.
  11. davidwb
    Holland.
  12. davidwb
    Holland.
  13. ombreetsoleil
    ombreetsoleil Senior Member
    Pictures
    I took some picture of the new 102 meter Feadship.
    It looks so big!!!
    I really don't know how they are going to finish it at this location.:confused:
  14. Yacht News
    Thanks for the photo! What's the largest Van Lent can handle again?
  15. ombreetsoleil
    They have different locations.
    Feadship bought a location a while ago in Makkum in the north of Holland for the big ones. That's why i am surprised that they are building this one at a location which is very difficult to reach for yachts this size through small rivers and canals.
    The yard in Makkum is able to handle yachts up to 120 meters, that would be a more logical location for this big boy.
  16. Telemachus
    Chicago
    This discussion on size has stimulated yet another question in my mind: it seems as though with length, the cost of a yacht is not linear, but rather it rises more quickly, which I assume is a function of volume; therefore, is there a formula for maximum volume with respect to length in terms of stability/seaworthiness, etc.?
  17. ombreetsoleil
    Strange when you think about it, this yacht has the same width as a yacht half his size.
  18. davidwb
    Holland.
    Ecstasea: length: 86 meters, beam: 11,50 meters
    Musashi: length: 88 meters, beam: 16,50 meters
    Lady Christine: length: 68 meters, beam: 12,50 meters
    Archimedes: length: 68 meters, beam: 12,30 meters
    Ocean Victory: length: 76 meters, beam: 13,60 meters
    Tango: length: 78 meters, beam: 12,20 meters
    Air: length: 81 meters, beam: 12,00 meters
    Hampshire Two: length: 79 meters, beam: 12,70 meters
    Predator: length: 73 meters, beam: 11,40 meters
    #1004: length: 99 meters, beam: 16,50 meters
    Hull 808: length: 102 meters, beam: 14 meters
