Click for YF Listing Service Click for Westport Click for Nordhavn Click for JetForums Click for Abeking
Vacuum pump heading holding tank banging
Discussion in 'Carver Yacht' started by Scallywag2, Jun 6, 2014.
  1. Scallywag2
    Scallywag2 New Member
    Burnham Harbor
    2003 Carver Mariner 350. When the vacuum pump runs, it starts out quiet then bangs like someone knocking on the door. Anyone had similar? What did you do?
    Sounds like air entering the line. Probably a bad seal.
  3. Dave Stranks
    Dave Stranks Member
    Coal Harbor Vancouver
    Pumping the liquid (with weight to it) and when it hits air it starts to jump around.
    The mounting brackets are loose or broken on the pump itself or maybe the rubber isolators are worn out on the feet where they mount
    This or it's possible that your vent is clogged and the water it's pumping cannot be pumped into the tank.
  5. Pascal
    I ve had two doing this... One had a loose motor assembly, all 4 bolts to the plastic brackets where gone and the motor and gear where flapping around.
    The other one is a mystery, all the bolts are tights, rubber mounts too. Only knocks 4 or 5 time as vacuum peaks before turning off. One of these ain't broken enough to fix it :)
  6. Dave Stranks
    Dave Stranks Member
    one other thing if the hose is relatively new
    And If the distance from the pump to the toilet long check and see if the hose is secure to some thing at least every 2 feet
  7. Scallywag2
    Burnham Harbor
    Thanks Dave Stranks. I'll look into the mounting and the hose. Good ideas.
  8. Scallywag2
    Burnham Harbor
    Thx Pascal. This is really helpful. I'll look to the mounts.
