Click for Nordhavn Click for Burger Click for Delta Click for Nordhavn Click for YF Listing Service
Vacuflush toilet keeps pumping longer than usual.
Discussion in 'Carver Yacht' started by Ruffinit, Jun 23, 2015.
  1. Ruffinit
    Ruffinit New Member
    New Berlin, Wisconsin
    My vacuflush toilet pumps longer than it use to. Bowl does not leak, Any suggestions?
    How long has it been since the duck-bill valves were serviced in the vacuum generator pump?
    #1 cause for this problem.
  3. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Yes, probably the duck bills - 2 upstream and 2 downstream. Lube w/ Vaseline, make sure you have them oriented correctly, and don't tighten the connections too tight. If that dosen't fix it, you may have a leak at the vaccum pump- you should be able to hear it. Replacing the vaccum pressure switch is easy. Just remove the wires, unscrew the old one, lube the new one w/ Vaseline, and screw it in - again, not too tight.
    Use superlube grease instead of Vaseline. Vaseline is petroleum based and can effect the rubber seals and duct bills over time.
