Click for Walker Click for Ocean Alexander Click for Delta Click for Westport Click for Burger
Vacuflush head repair
Discussion in 'Technical Discussion' started by CTdave, Jun 27, 2019.
  1. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    ive never had one of these apart but the round piece that turns when flushed is not turning. It’s free and can be turned by hand but it doesn’t move when the peddle is pushed to flush. I took the peddle cover off and see the water valve but I’m stumped.
    Round piece that turns? The big clam shell door in the bottom of the bowl?
    If so, the shell has cracked on the shaft end.
    Domestic, who now owns Tetford-Sealand, has the IPB and manuals on their web site.
  3. Capt Ralph
    If you have never worked on these heads, your time has come.
    Not to bad of a job if you can get the base band off.
  4. Pascal
    Sounds like it is indeed cracked. Weird because in all these years I never had to replace the actual ball valve. The seal, yes... but not the valve.
  5. Capt Ralph
    I have once. Somebody had a heavy left foot.
  6. CTdave
    Oh boy, sounds like fun in the right space. I found the parts so again, thanks everyone!
  7. Alan Oakley
    Alan Oakley New Member
    Kansas
    I have replaced the whole assembly myself. I bought the kit which includes everything you will need. Make sure you pump out and flush the holding tank. I watched a youtube video and it actually very simple.
