Click for Ocean Alexander Click for JetForums Click for Abeking Click for Westport Click for Northern Lights
Unstable after installing new battery bank
Discussion in 'Technical Discussion' started by cgoodwin, Nov 18, 2014.
  1. cgoodwin
    cgoodwin Member
    USA
    The vessel is a 1952 Feadship, 56' LOA, 13'2" Beam and a draft of 4'6". Steel hull, twin 671 detroits.
    I just finished installing 16 AGM batteries weighing 100lbs each. They were installed almost exactly in the center of the vessel lengthwise. They are just slightly to port of centerline and are about 20" below waterline.
    As soon as I installed the bank I noticed that the vessel has become "tippy", as I step onto the side deck from the dock she now noticeably rocks, which she had previously not done.
    I must say I'm a bit confused as I would think that adding 1600 lbs of weight below waterline would have made her more stable, not less.
  2. olderboater
    Where were the batteries before and how many and what weight?
  3. AMG
    This can happen with added weight low down. Compare with a sailing boat without her mast, the movement is faster.
  4. jhall767
    jhall767 Senior Member
    Middle River MD
    You'll probably find that initial stability has decreased but that reserve stability is increased. Possibly due to a change in the water line. Initial stability is mostly governed by hull shape not ballast. The added ballast won't make much of a difference until the boat has heeled enough to use it as a righting moment.
  5. Opcn
    Opcn Senior Member
    To jhall767's excellent response I will only add that the waterline isn't the only thing to think about in initial stability. If the shelf you put the battery on is 20" below waterline and the battery is 16" tall then you loaded 1600 lb's 12" below waterline, and slightly to port. The center of mass of these batteries is undoubtedly above your boats initial center of buoyancy , which would detract from initial stability. As the boat heels what jhall discussed comes into effect and the center of buoyancy moves and you get a righting moment from those batteries that will help put you back where you want to be.
    I'm no naval architect but will also mention that displacement hulls have a certain amount of water they are supposed to displace. And a certain amount of weight that the hull design allows for for the hull to have the correct displacement for it's length/beam/shape. If you add weight over that, it will definately effect the righting motion that was designed into the hull design. A 13'2 beam is very narrow for a 56' LOA by today's standards and will be much more tender compared to if it had a 17' beam. While I don't think it will have any adverse effects in regards to safety, it may effect ride a bit. Can you put the boat on a diet and lose a little weight elsewhere?
  7. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    Did you replace these batteries (and they are a different type/weight than the ones replaced) or are they a new addition to the boat? 1600 pounds not in the lowest of the bilges can have a huge effect as you have noticed.
    The OP stated that they are for an inverter bank and all of them were added to support a new inverter bank and didn't exist before.
  9. cgoodwin
    cgoodwin Member
    USA
    Originally fitted with 8 large 8v batteries, these were removed four years ago. I installed two AGM batteries outboard of each motor for start banks. No change in boat. I recently added 16 AGM batteries for a new inverter bank. These are well below waterline, but since installing the vessel seems to roll more easily, ie; I used to step on the gangway from the pier and the boat would not move, now she does. I would have thought that adding more weight below waterline and centered would have made her less likely to roll, not the other way around. Just forward of this bank is the midship tank which holds 450 gallons of diesel. It is now and had been empty for the past 6 years, I imagine the additional 3600 lbs of fuel will stabilizer her more. We'll see soon as I have finished the repair of the tank.
    My question is why adding more weight below waterline would make her roll more easily. I could see it if the weight was above the center of gravity, but I really done see how that is possible as the batteries are lower than the two huge twin diesels....
  10. Capt J
    Weight is weight and makes her less bouyant. Think of how much more tippy a dinghy is when it has 8" of standing water in it, even though the weight is at the lowest point you can possibly get.
  11. olderboater
    You changed the buoyancy factor of the center of the boat without changing it on the sides. Also the fact they're off center might play a role as you've created an imbalance. Altering any part of weight distribution can impact many other things. If anything the depth of it below waterline is a negative, not a positive. Vertical balance is important too.
    Generally a boat with its mass distributed toward its perimeter will have a much higher resistance to changes in motion. It is therefore evident that it will be more dynamically stable. This can be intuitively thought of as the "gyroscope" effect.
    Also, has this changed your waterline any?
    The difference in this and the tank is I assume the tank is spread largely over the width of the vessel, not concentrated solely in the middle.
    See, you put your AGM's to the outside of the engines.
    Really think of standing with your feet together versus with your legs spread. Which gives you the best base?
  12. Marmot
    J, have you ever heard of "free surface effect"?
    This thread makes it clear that there are many misconceptions regarding stability and trim. It would serve the readership well for some to spend time with a good book on stability or a computer stability program and see exactly what happens when weight is added or removed from a given location.
  13. Opcn
    Opcn Senior Member
    Spreading the weight out to the sides will increase the moment of inertia and thus the roll period, making it slower to respond to dynamic forces (like stepping onto the boat) but it won't actually affect ultimate stability. If it lists 3 degrees when he stands on the rail with the weight in the center it will list 3 degrees when he stands on the rail with the weight distributed. Distributing the weight can make it more comfortable, however.
  14. karo1776
    karo1776 Senior Member
    Gone
    Exactly right on... however, the comfort or feel of the boat will be better with the longer roll period. This is something that is very important to naval architects and those that are sensitive to sea sickness. Basically you messed up you boat... should have hired a professional naval architect before installing things on the boat and unintentionally changing its dynamic response is the lesson here!
  15. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    The preferred solution would have been to either split the battery bank up and put them equidistant from centerline as far outboard - port and stbd - as possible,, typically outboard of your engines if space / access allows or to place them in a single bank athwartship (across the beam).
    Heavy weight, down low placed along the centerline would not be the first or second choice for the reason you found out, but the choices are typically complicated by space available in compact machinery rooms.
  16. Capt J
    Hatteras has always put their fuel tanks fore and aft right smack dab in between the 2 center stringers. But I guess they split up enough other stuff/weight?
  17. Marmot
    I suggest that any difference in susceptibility to roll due to the transverse location of added weights in a narrow beam vessel is so slight as to be of zero consideration. If anything, placing heavy items outboard exposes them to more rapid accelerations and will require heavier supporting structure.
    As far as transverse stability is concerned, if the weights are equal, the transverse center of gravity will remain the same, and if the weight does not lower the CG then the roll rate will not change.
    If the added weight is located below the initial vertical center of gravity, VCG will be lowered, GM will increase and produce a faster roll rate. That condition is probably what the OP describes as instability. The new condition is of course exactly the opposite of what the thread title claims, his boat is more stable.
  18. PacBlue
    Dana Point, Ca
    It seems to me that the OP is describing initial stability.
    He has essentially added an interior "keel" to what I assume is a round bilge narrow waterline without the added benefits of the dampening effects of a traditional external keel.
    So I would still stand by my approach.
  19. Marmot
    Considering the boat was at a dock and not suffering from compartmental flooding, that is a reasonable if superbly obvious conclusion.
    He probably lowered the VCG, that is the sole reason the roll period changed.
    Consider the statement made earlier in this thread "Compare with a sailing boat without her mast, the movement is faster." That sailboat still has the same keel as it did with the mast, removing the mast increases the GM and that is what shortens the roll period. If we use your theory, that sailboat would roll slower since the keel doesn't have to dampen the angular momentum of the mast.
  20. PacBlue
    Dana Point, Ca
    I am not presenting an argument to you regarding GM, Roll period, sailboats/masts or whatever.
    I will say it again, sloooowly this time - the OP will reduce his perception of a decrease in his initial (form) stability by NOT putting all the weight on centerline in a concentrated area, but by placing the weight symmetrically at the perimeter of the available machinery space on this particular MY.
