Click for Burger Click for Walker Click for Abeking Click for Perko Click for Furuno
U-joint, CV-joint, Thompson coupling
Discussion in 'Technical Discussion' started by brian eiland, Mar 16, 2007.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
  2. MaxResolution
    MaxResolution Senior Member
    Little Rock
    That's a pretty cool looking piece of metal work. Once again, I was inspired to search for this equally unique ball-transmission which offers the simplest direct transfer of energy with only three moving parts. Since the site is down, I suppose they couldn't find the needed financing. Of course, there are dozens of similar patents which require many geared concentric rings. The proof now is how well such an innovative product sells.
    I did find a cool gas bike engine in a wheel, if you're up for awarding bonus points? "Perfect aboard a yacht!" http://www.revopower.com/
  3. Codger
    Codger YF Wisdom Dept.
    Western Canada
    Good find! Looks like a mechanism worth watching. It'll be interesting to see what happens to these joints as they get thrashed around in the dirt over time. The joint is more expensive to build than a "U" joint but if it lasts significantly longer then it'll have a shot. I've seen U joints and CV joints fail in under 4 months in mining environments.
  4. brian eiland
    Updated News
    Anyone visited this site lately? I still find this piece of equip quite interesting.
    http://cvcoupling.com/index.php?option=com_content&task=view&id=44&Itemid=41
    And there's something special for helicopter enthusist:
    "Following a request from a jet helicopter manufacturer, for help with the design of the tail rotor, our engineers set their sights on designing a compact version of the Coupling for relatively low torque, high-speed applications to operate at angles up to 10 degrees"
