Still trying to trace the path of power cables and tv cable from connection on stern(upper port) to and thru engine room to distribution panel. 1988 3807 Aft Cabin. Any help appreciated. Eugene
I have the same boat. Although I've never needed to trace them, I'm pretty sure they run along the port side (behind your head board, the clothing closet and into the panel. That would be my guess. You (or a nearby Romanian gymnast) may have to lift the mattress, climb into the bilge and look up into the void. While you're there, replace the aft bilge pump hose. It is most likely brittle and full of holes by now. Good luck.
