Click for Nordhavn Click for Perko Click for Glendinning Click for YF Listing Service Click for Ocean Alexander
Trim issue on Starboard motor
Discussion in 'Carver Yacht' started by lionfish37, Jun 30, 2011.
  1. lionfish37
    lionfish37 New Member
    St Joe Michigan
    The boat was dy docked for two years and forgot to check the trim when it was out of the water. they both engage when putting down the up on the starboard wont click or engage. I check the fuse and it is good. Any ideas?
  2. tommyfmu
    tommyfmu Member
    Freeport, NY
    Check the fluid level that drives the pistons; it's the same as automatic transmission fluid if it's low.
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    There should be a trim relay too, check that.
  4. lionfish37
    St Joe Michigan
    YEs I checked that first they are filled. The one thing I noticed is next to the selinoid there is a device that had a tab on it saying this srew is attached to the positive battery. That tab is broken off that drive. Is there a contact point there? so you can here the selinoid when going down but nothing going up.
  5. K1W1
    Can you post any photos of these mystery components and does the Stbd Side look exactly the same as the Port Side?
  6. lionfish37
    St Joe Michigan
    Yes I can tonight
  7. lionfish37
    St Joe Michigan
    It was a fuse.
