Click for JetForums Click for Burger Click for Cross Click for Burger Click for Northern Lights
Transom thru hulls
Discussion in 'Post Yacht' started by Greg Page, Mar 9, 2025 at 11:42 AM.
  1. Greg Page
    Greg Page Senior Member
    Annapolis MD
    The marina suggested we replace the transom thru-hulls for the cockpit hatch surround drains and the aft bilge pump outlet since they do not have the 'mushroom' on the exterior. They are about 8-10 inches above the waterline.
    Seems like a good idea but wondering if other Posts have just the flush outlet or have a traditional rounded flange on the outside? Anyone have problems with an original flush outlet coming apart/loose?
  2. boatpoor
    boatpoor Active Member
    Mine are just like yours and I've never had an issue with them. They've worked fine for 32 years.
    Greg Page likes this.
  3. Capt Ralph
    I can only figure the idea is to (maybe) reduce any stains on the hull under the the thru hull outlet.
    If this is not a problem, revert to one of my best boat rules;
    If it's not broke, don't fix it.
  4. Greg Page
    Annapolis MD
    Ours are starting year 36. I'll look them over once it's unwrapped to check from inside but am leaning to leaving if I don't see anything loose or cracking. They must be glued in as there is also no flange, nut or ring on the inside of the transom. Just a straight tube.
  5. chesapeake46
    chesapeake46 Senior Member
    Same here.
