Click for YF Listing Service Click for Burger Click for Westport Click for YF Listing Service Click for Cross
Transom angle 1969 38' Roamer
Discussion in 'Chris Craft Roamer Yacht' started by jflongwell, Apr 20, 2009.
  1. jflongwell
    jflongwell Member
    Watkins Glen on Seneca Lake
    I am putting a swim platform onto my 38' 1969 Roamer.
    The transom tilts forward and I am trying to determine the angle to make the braces to. I have figured the transom is at about a 8 degree angle. Any one know a definite figure?
    John
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    You could always make up the difference with wooden wedges.
  3. jflongwell
    jflongwell Member
    Swim platform
    I am not sure if that would hold very well. I am having the brackets modified with an 82 degree angle. I am bolting the platform to the transom with 1/4" SS bolts. Do you think these are sufficient? Getting to the transom with the water tank there is a real pain!!!
    John
  4. Ken Bracewell
    Somewhere Sunny
    You would bolt right through the wood, using them as spacers. This will also help to alleviate dissimilar metal reactions.
  5. q240z
    q240z New Member
    zsedr
    The swim platform on my 46 Roamer is enormous and used mahogany spacers as Mr. Bracewell has described. The platform is made of stainless, as are the 3/8" bolts. I will use the same mahogany spacer approach when I mount mine, but will cold mold them by saturating them in epoxy before painting them with the appropriate top coat or bottom paint.
