Click for Glendinning Click for CL Yachts Click for Abeking Click for Burger Click for YF Listing Service
Towing boat to Bahamas next month
Discussion in 'Center Consoles, Tenders & Dinks' started by CSkipR, Apr 20, 2013.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Okay I have towed a 15ft BWhaler the past 3 years to the Bahamas with no issues. I tow approx 130-150ft back and trim the motor slightly down and tie the steering up.
    This year I'm towing a larger 19' PioneerSF to the Bahamas. This boat weighs approx 1500 lbs more than the Whaler and has a modified vee. I'm wondering if I will need to keep the engine prop slightly in the water or will be able to totally raise the engine? Any thoughts on this?
    Since its hydralic steering I don't need to tie the steering up.
    With the Whaler I was able to tow it running 24-25 knts. Not sure if I will be able to do that this time.
    You want the 19' engine somewhat in the water.........both for tracking.....and to slow it down if you need to slow down fairly quickly. You won't notice it too much more once it's up on plane, if you have the proper harness/bridle.
  3. CSkipR
    CSkipR Member
    Thanks for the feedback.
  4. Beau
    Beau Senior Member
    Beaufort, NC
    SkipR
    What was the result on your generator problem?
  5. CSkipR
    CSkipR Member
    Beau,
    I replaced the heat switch (sensor like) by the thermostat. Cheapest repair I have done this year. $20
    Skip
