Click for Cross Click for Mulder Click for Westport Click for Westport Click for YF Listing Service
Today started with a Lightning Strike
Discussion in 'General Yachting Discussion' started by dewald, Sep 18, 2023.
  1. dewald
    dewald Member
    Treasure Island, Florida
    This morning at 8:45 having a cup of coffee look out at the boat, then a big flash & a Boom. Lighting hit one of the VHF antennas on the boat. Known damage as of now. 1 Vhf antenna, 1 VHF Radio, 1 AM/FM Radio, 1 Cruise air conditioner, Auto Pilot, Furuno Chart plotter, Radar, Fish finder, Etc. Some interior lighting and will keep looking tomorrow. At least it did not blow a hole in the boat and have it sink at the dock. Already contracted the Insurance Company. Any help on how to handle - deal with the Insurance Company is appreciated.
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Assume that EVERYTHING that is wired on the boat is fried. Right down to heads.
    Insist on thorough out of water survey from insurance company. There are people that specialize in this type of thing, find one, they'll pay for themselves.
    And don't allow the claim to close after repairs, keep it open for a full year.
    gr8trn, Capt Ralph and bliss like this.
  3. bliss
    bliss Senior Member
    Racine
    Excellent advice. I was hit when I had guests aboard. No one hurt VHF was fried. Travelers was my insured. and they paid to have the boat pulled. The neighboring sailboat shared the hit and also lost their VHF. We both were lucky!
    We assisted with repairs on a 58 Southern Cross after a strike.
    Cummins ECMs, controls altenators, charge controllers.
    Then; ALL electronics, Sat system, anything with a LCD or LED display, All A V stuff and half of the AC equipment.
    Later discovered the battery chargers and most of the batteries.
    There was nothing left of the two VHF sticks.
    Methane explosion in the black water tank.
    No damage to the hull.
    Insurance company covered everything.
    The SS rails on the fly-bridge did polish back to a nice shine.
    Just lil pits in the SS rail but owner wanted that left on for his personal reasons.
    They were onboard when the strike happened.
    Old Cummins Smart Crap replaced with Simrad 7" displays with new CanBus I/O controllers.
    Took about a year to fix everything.
    Insurance company said; the one year clock started after the last of the original repairs were made and boat delivered.
    Insurance company did not drop them after the claim.
    Are you out of the water yet?
    Now is the time to re-test ALL of your equipment. You may have over looked some things....
    I'm sure that mag in the radar took a hit, or at least degraded.
  5. chesapeake46
    chesapeake46 Senior Member
    Check everything from the windless to the trim tabs and all things in between.
    Oh, on that Southern Cross.
    Windlass was fine, trim tab pump was fine. The lil wires from the tabs to the dash that offer tab position, they evaporated.
  7. dewald
    dewald Member
    Thanks for all the feedback. Please forgive my naivety, why do I need to have the boat pulled out, what are they looking for.
  8. Capt Ralph
    If you took a direct strike, that electricity went to the water on some path thru your boat. The fiberglass may be damaged.
    Also, thru hull fittings may be damaged.
    I have witnessed hulls where the FRP was just mush, the bottom paint (what was left) and silt clogged the glass strands & mush well enough to keep the hull from sinking.
  9. Pascal
    I agree. You need to haul out to assess the hull and thru hulls. I would inspect every thru hull for any sign of burn marks. You could probably do a short haul in the sling as for a survey. Unless a problem is found.
    In the mean time check and run every system incl engines, gens, thrusters etc. if wiring was damaged something may work for a short time until damaged wiring heats up
  10. islandgirl
    islandgirl New Member
    Honolulou
    I'm a newbie....and uneducated about lightning strikes. Can any boat be struck? What can you do to lightning proof your boat? I read somewhere about a FARADAY CAGE. How does that apply?
  11. RossC
    RossC Member
    Rehoboth Beach, DE
    Maybe park beside a sailboat. :)
  12. d_meister
    d_meister Senior Member
    La Conner, WA.
    I surveyed the electrics and electronics on a yacht in Ixtapa that had been struck by a side-flash. The yacht in the next slip was the primary hit. Everything in the yacht that had a semi-conductor in it was inoperable. There was a hand-held Magellan GPS in a drawer with no batteries in it that would not power up with fresh batteries. The captain was certain it functioned previously. There was a power supply for the hydraulic pack that lifted hatches that was very simple. It was a transformer with one diode in a metal enclosure, and the diode was damaged. Windlass AC control wouldn't work. Replaced the contactor, and good again. Most, if not all, of the damage was from EMF.
    https://www.qwant.com/?client=brz-vivaldi&q=emf+from+lightning&t=web
  13. Capt Ralph
    EMF is a factor that can effect devices a few hundred feet (or more) of a direct strike.
    Also lil streamers can stretch out and create mini paths from & TO the main lightning bolt.
    dewald states his VHF stick was hit. If there is anything left of it, it may have been a EMF wave or lil streamer spike that hit him.
    Because, were all still guessing as to how hot the hit was, I'm still concerned about everything including the hull. Boat out of the water yet? Proper surveyor looking her over yet?
    On that bad hit I mentioned above, The insurance company sent out their own tech that worked with the owners surveyor very well. After discovering an issue with the integral black tank, it was pumped out and cleaned for a more through examination.
    I really hope dewald's insurance company steps up and checks everything for Him.
  14. dewald
    dewald Member
    Hi all, still here. Just trying to get my act together. Thanks for all feedback. The wife takes up a lot of my time. She has a leg wound that we have trying to get healed going on 2 years, averaging 2 Dr visits a week and 2-3 days of being in the hospital about every 4 months., but there light at the end of the tunnel. Ralph, you may be right on, part of the VHF stick is still there. Boat is still in the water behind the house. My dive can't come out until Sunday. Going to call the Insurance company again tomorrow to get a better understanding of what they told me. I was a little bit Frazzled during our first conversation. Got ahold of my God Child last night, He has been a yacht broker for quite a while and just recently took a very nice job with one of larger yacht brokers in the US with offices in Europe. I'm sure you all know what he told me to do! I will post more tomorrow. It's cocktail time.
  15. Capt Ralph
    Southeastern just dropped a new 24Kbtu self contained AC unit on me.
    No damages to the box.
    Yes, Now it is cocktail time.
