Click for Cross Click for Westport Click for YF Listing Service Click for Perko Click for Burger
Thru-hull and impeller question
Discussion in 'Luhrs Yacht' started by Sarah Hempel, Sep 5, 2020.
  1. Sarah Hempel
    Sarah Hempel Guest
    Is a thru-hull high speed pickup required for the mid ship air conditioner to run while underway? Also what are some tricks to remove a stuck impeller (port engine d4 260) We have a 2008 31 open
    The scoop A/C raw water pick ups are a great idea for the A/C water inlets.
    With all that water, air and froth, the A/C raw water pump needs all the help it can get while operating your ship at some speed.
    Also helps keep your pump primed when your anchored or tied up ready to get primed, ah , er, relax and want some cool air blowing.
  3. Capt Ralph
    On your engine water pump; Not shure of any tricks on a Volvo D4 but try this;
    Close sea cock, remove impeller cover, while the engine if bumped over, spray WD40 in and on the impeller.
    If the engine tried to start, ensure a good dowse of WD40 and shut down the engine.
    The WD40 keeps the rubber from dragging on the pump housing.
    With a proper impeller puller (Jabsco) yank that puppy out.
  4. Pascal
    An impeller puller is ideal, have you tried that ? Some impellers have a female thread in the hub so you thread a bolt and use a socket to crank it out.
    as to the AC pick up, it helps on boats where the pick up is too far forward. You d think boat builder would think about that... the best type of scoop are what’s called South Bay strainer, it s a wedge with a SS mesh. It s great in areas with sea weed clogging the strainer too quickly. Kills two birds with one stone
  5. Sarah Hempel
    Sarah Hempel Guest
    Thanks for the advice on the scoop. We will keep our scoop. And still on hunt for a puller for the impeller. Boat is on land right now so trying to do all of this while it is dry docked.
  6. NYCAP123
    That's good advice on the South Bay strainer. They were designed to block eel grass, but keep out all sorts of stuff that'll clog, and while she's on the hard is the perfect time to install them.
  7. Pascal
    Great with plastic bags too. With conventional slotted scoops plastic bags get stuck in the slots and don’t fall off when suction is shut down. With the mesh, they fall off
